Results 1 to 4 of 4
Thread: 3SGTE question
    Low rep 1st year Apprentice
    Green Valley
    Default 3SGTE question
    Excuse my ignorance, just need to know someone's experience on running over-size valves.
    Does it help the turbo spool quicker? And won't there be the problem that the valves will be kissing the piston?
    What sort of cams should I run with a Garrett gt3037 and what other mods can I do to increase the air volume?
    Default Re: 3SGTE question
    The bigger valves improve volumetric efficiency quite nicely. You can get 1mm oversize valves onto the stock seats.
    I don't know about getting the turbo to spool quicker, maybe it will if you setup the cam timing to favour that.
    You should make sure that the pistons are flycut correctly for the size of valve you are using.
    In my car I'm running Wade cams, 266 degrees advertised and 10mm lift. I suspect these won't fit straight into a Gen2 head though. They would work nicely with a decent size turbo though, on mine with a TO4S I made 203rwkw at 10psi.
    If by "increase the air volume" you mean improve flow then look at getting a better intake manifold and head porting.
    Green Valley
    Thanks Joshstix, that’s a good figure for a t04 on only 10psi
    Welcome to the Darkside! Automotive Encyclopaedia -==L=a=N=c=E==-'s Avatar
    Rosewood
    Running over sized valves and high lift cams, you will turn the engine into an interference type as well.
    Personally, cams for that size turbo, i'd run 264's with your choice of lift (i'd run stock, to try and keep it non interference). Keep the idle relatively the same, with more topend/torque (depending on how you degree them)
  1. To 3sgte or not to 3sgte
    By General_Bupkiss in forum Tech and Conversions
    Last Post: 23-03-2006, 04:23 PM
  2. 3sgte and 4agze standard weights?
    By Taxi>Maxi in forum Tech and Conversions
    Last Post: 20-03-2006, 06:55 AM
  3. 3sgze Vs 3sgte
    By NeoNasty in forum Tech and Conversions
    Last Post: 18-02-2006, 03:03 PM
  4. Bigger injectors 3sgte
    By Jorrs in forum Tech and Conversions
    Last Post: 05-02-2006, 09:41 AM
  5. 3sge - 3sgte CAS - interchangable?
    By Steve M in forum Tech and Conversions
    Last Post: 20-12-2005, 08:15 PM
