check the wiring between the temp gauge and the temp sensor -
ground the temp sensor cable and watch the temp gauge needle go up, if you disconnect it from the motor the needle should go down.
Check the temp sensor with a known good sensor, or let motor idle for 5 -10 minutes, drain a bit of coolant out the bottom of the radiator and measure with a thermometer. compare with your temp gauge.
Check the thermostat by removing it and placing it on a bucket of boiling water, it should open fully.
