Results 16 to 27 of 27
Thread: Brake squeal - NOW faulty pads perhaps... anyone seen this before?
    Default Re: Brake squeal - NOW faulty pads perhaps... anyone seen this before?
    That is very lucky you found that before a failure occurred.
    It has happened to me before also with rear drum shoes. The friction material seperated from the backing plate... corner entry on a spirited run, not fun at all. A couple of quick pumps of the pedal gave me line pressure again but it was brown trousers time!
    I returned the shoes to the place I bought them from and got them to machine the drums where they had been scored by the backing plate.
    The shop was extremely apologetic, but when I took it all apart there was a small amount of diff oil that had found its way onto the shoe lining. I think this might have helped the bond fail but I'm not too sure...
    Anyway my point is, check for any small sign of contamination (brake fluid, shock oil, anything)
    The other thing is, current OEM pad manufacturers have a rule that if a pad is dropped at all, it must be binned regardless of how good it seems. Any idea whether your have been dropped?
    Little chance of contamination in this case, shocks are brand new, and dry, calipers are less than 2000km old, and dry, hubs are sealed well.
    Pads haven't been dropped since being in my possession, but that's not to say it couldn't have happened prior.
    Will see what the shop says tomorrow......
    Thanks for the pointers.
    Gearwhore. Backyard Mechanic
    Oct 2008
    Interesting, my QFM pads have been a bit squeaky but I put that down to them being totally underused. Might have to pop them off when I get a chance and take a look.
    The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
    Canada
    Default Re: Eliminating brake squeal
    Manufacturing fault perhaps? Anybody seen this before?
    Phil
    I have seen it many a time while working at the dealer.
    Pad separation happens to OE pads and to aftermarket pads; it is usually more common with aftermarket pads.
    Generally the two most common triggers seem to be age (presumably heat cycling) and rust. (In the case of my dealer, it was rust due to road de-icing salt.)
    I am not accustomed to seeing this on new pads.
    Hoppers Crossing
    QFM will be very interested - recommend you contact them
    Your Hoppers kit will be using VT twin piston calipers. They are noisy as HELL when you don't apply that red anti squeal stuff, I've changed many a pad on these and have had these sort of complaints - until the red anti squeal stuff was applied
    Tried... couldn't get a response to email or phone. GSL Rallysport on the other hand were very helpful in discussing the issue, even though I hadn't purchased the pads through them.
    Quote Originally Posted by Grega
    VT Commodes run a DB1375 pad? Since when? The Falcon calipers in my Hoppers kit are still similar PBR design, though not identical. I've run these calipers (2 sets) with 4 different brands/compounds of pad, and only the faulty QFM's made noise, the rest were/are perfect.
    Jun 2008
    This is also a recall campaign item. It could cause a serious accident.
    Oct 2008
    Oh crap, I should definitely check mine today.
    EDIT: Pulled the pads off, no gap. Noticed two other things though:
    1: Absolute shitloads of brake dust. Everywhere. MUCH dustier than any other pads I've ran before
    2: KU31's are a fucking awesome tyre.
    Nov 2009
    tasmania
    have you checked to make sure the backing plate isn't rubbing on the disc?
    Oct 2008
    Quote Originally Posted by william View Post
    ...I don't understand. The pads are only 15000km old, still around 80% meat left on them
    Nov 2009
    tasmania
    the shield on the inside of the rotor
    i would contact them again and let them know you are talking about your problem on a bunch of prominent car forums and would like the matter attended to so you can close out your threads.
    By The Witzl in forum FAQ
  2. MS50/60 & 70 Front brake upgade - By Shep
    By TheToyman75 in forum Tech and Conversions
    Last Post: 04-05-2009, 08:34 AM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
  4. Brake upgrades for FWD/AWD 5x100
    Last Post: 06-09-2005, 11:38 PM
