Results 1 to 8 of 8
Thread: RN90 Hilux 22R wont select OD
    Junior Member 1st year Apprentice JZX083's Avatar
    Mar 2009
    Default RN90 Hilux 22R wont select OD
    Hey guys,
    Just a little help needed guys, if someone could point me in the right direction that'd be great. The Auto on my RN90 hilux will not select OD. Obviously the OD switch works but im not sure where to start.
    Cheers.
    Keep Left unless Oversteering!!!
    92 Silver JZX83 Cressida Grande Auto (Daily)
    91 Blue JZX83 Cressida Grande Manual GT3040 (Drifta)
    Your mum loves my Grease Monkey TasCressida's Avatar
    Apr 2008
    tasmania
    Default Re: RN90 Hilux 22R wont select OD
    i assume this a stock engine and trans.
    Stock hiluxs arnt my forte.
    Unless it has a CRS kit with a 304 lol
    maybe the over drive switch has come unplugged?
    Switch has shit its self.
    if its kick down style it may need adjusting. (cable from throttle body to the trans)
    sounds silly also but have u checked the oil level? but being just over drive i doubt this is the problem.
    hope that helps.
    just some quick checks to do.
    JZX90 Lovin'
    Mar 2009
    Yeah mate all stock standard,
    Oil level seems ok, but i can check the other stuff!
    Cheers for your help!!!!
    Nov 2007
    I also am no hilux expert however I do know that the missus Rav4 won't go into over drive until the engine has reached a certain temperature. Perhaps it could be one of the coolant sensors has come loose or gone kaput.
    Glen
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
    Mar 2009
    G'day mate,
    I knew about the not going into OD untill warm but there would be another place to look thanks for the suggestion!!!
    Cheers!
    Tasmania
    I presume it runs the same tranny as the MX 62 Cressida(A43D)if so check the solenoid on the passenger side of the box.It should have a single wire coming off this as the solenoid earths to the box itself.Find this wire and disconnect it from the loom and plug a jumper wire into it and put it to straight 12V and you should hear the solenoid engage or check to see that the wire hasnt broken off the top of the solenoid.
    If all this works then your O/D switch is stuffed.
    Cheers Brett.
    Mar 2009
    hey brett,
    Thats great thanks for that. Thats the right box number. I'll check that solenoid!
    JZX083
    vic
    The solonoids can become intermitant , Check to hear if it clicks when you apply power to it .
    Dave
  1. Hilux 22R to 22RE Conversion Help needed
    By MrBags in forum Tech and Conversions
    Last Post: 09-03-2013, 12:38 PM
  2. Hilux Rn85 22R Carby ignition timing?
    By vanman in forum Tech and Conversions
    Last Post: 11-02-2009, 07:09 PM
  3. 1988 sr5 hilux 22r stalling issue
    By Geoff897 in forum Tech and Conversions
    Last Post: 23-12-2008, 10:05 AM
  4. Help Needed - Auto Electrical RN90 Hilux
    Last Post: 29-10-2007, 12:09 AM
