Results 1 to 4 of 4
Thread: TA22 Dash
    Hooligans Holiday Grease Monkey kickstartRA28's Avatar
    Apr 2009
    Default TA22 Dash
    Anyone know how to get a good TA22 dash pad off the steel dash frame without wrecking it as it may be glued.
    Default Re: TA22 Dash
    The underside of the dashpad uses little pins that come through the metal frame. Once through, the pins have metal clips with teeth slide over them and keep the dash tight against the frame - so to remove the dash you need to remove the clips.
    I found when removing mine it wouldnt move high enough to get the pins out and was hitting on the windscreen.
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    after removing the pins, i used a scraper before trying to lift the dash pad. this allowed me to seperate the dash from the frame without lifting it and potentially cracking the dash pad...
    Carterton
    Best of all do the removal on a hot day. The dash pad is a bit more flexible and the glue gives a bit more.
    Mike
    71 TA22
    My Car
  1. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
  2. ta22 dash
    By ke30king in forum Tech and Conversions
    Last Post: 28-02-2006, 09:39 PM
