Results 1 to 7 of 7
Thread: ta22 dash
    tas
    Default ta22 dash
    anyone got any ideas on how to get my dash pad out i have undone all the clips and nuts and bolts and screws but it just wont come away from the car.
    any suggestions will be much appreciated
    Less cheese than a Grease Monkey andurils_sheath's Avatar
    Default Re: ta22 dash
    Hey buddy,
    had this problem, tis probably stuck down with some adhesive between the frame and the top section.
    Just keep tugging and itll unstick.
    tas
    cheers i will see if i can get it off without breaking it anymore than it already is
    Deal with the Frog Backyard Mechanic Cool1's Avatar
    Use a steel rule to part the foam pad from the metal frame!
    Built! not bought Grease Monkey SYC02T's Avatar
    Do you know about the pins that stick out of the pad down into the frame up near the window.
    They do tend to stick to the steel frame after 30 or so years sitting there undisterbed.
    I cracked mine trying to get it out, so DON'T unless you need to. It will just cause problems because you cant get them from toyota anymore.
    Administrator Domestic Engineer mynameisrodney's Avatar
    firstly make sure the whole edge is seperated from the steel like cool1 said. then starting in the middle, genlty lift it up just enough so the pins come through the steel, and put something in the gap to chock it up. work your way to the edges. once all pins are free, pull forward on the pad (lifting up on the lip is much more likely to crack it).
    this may be a long shot but if you are planning to take your windscreen out in the near future, take the dash out after. its about 1000 times easier without the screen in the way.
    chris
    tas
    yeah the thing is cracked to shit so im going to take it out and have a crack at recovering it but getting it out aint that easy i will have another look tomorrow
    thanks all, lloyd
  1. KE70 Panel Van Dash
    By Gleno28 in forum Tech and Conversions
    Last Post: 23-04-2010, 01:21 PM
  2. W58 into TA22
    By fade-e in forum Tech and Conversions
    Last Post: 26-07-2008, 03:42 PM
  3. 3TGTEU-W55 into a TA22 Any Suggestions?
    By Ta22boy in forum Tech and Conversions
    Last Post: 10-01-2006, 09:53 PM
