Results 1 to 12 of 12
Thread: Hydraulic Fan Solenoid - 3VZFE
    Question Hydraulic Fan Solenoid - 3VZFE
    Hi
    I'm trying to check my cooling system as my camry is still overheating.
    The fan is not turning as fast as it should be. I've read that they are controlled by hydraulic fluid coming from the power steering controlled by this solenoid and the fan PC.
    Now I want to start at the solenoid and read that its on or near the power steering pump.
    What does this solenoid look like? if its been disconnected this can cause the slow fan right? if its connected where do I start looking next?
    Thanks in advance
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Default Re: Hydraulic Fan Solenoid - 3VZFE
    Not sure where your getting that info from, but thermo fans installed in Camry, with 3VZFE engines are electronically operated. They are triggered by a water temp sensor which is located on either the thermo housing or the upper radiator inlet housing.
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    T'ville, QLD
    my camry had a hyraulic thermo fan, so they do have em
    no other help than that im afraid
    2T out 4A in....
    Well there ya go! Never seen one. Every Gen 3 Camry that i've inspected has had a thermostatically controlled, electric fan.
    Kind Regards,
    Kurt.
    vic
    4 cyl yes electric , all VDV10 are V6 and hydraulic fan
    Solonoid is a 50 cent round cylinder on p/s pump ,
    you can stop the fan at idle with yr fingers and
    if engines getting hot the fan really only roars when you rev it.
    Dave
    I've asked the same question in toyotanation and they reckon that it should go faster as soon as the engine temp is on normal
    maybe something else is causing my overheating...
    Im gonna get it tested on Wednesday, see what the experts say
    Junior Member Backyard Mechanic manny's Avatar
    If it's anything like the xZZ3x Soarer hydraulic fan solenoids, if you unplug the loom to it or unplug the loom to the temp sensor, it should run at max speed.
    GSE20 IS250 - daily
    if it goes at max speed? what does that mean? would the ECU Fan or the solenoid or the switch would be the culprit?
    update
    Thermostat doesnt seem to be opening top hose hot, and bottom hose cold to feel. So replaced it with a brand new one, check the flow of radiator, bottom hose/pipe and still overheating just from driving around the block.
    Took the thermostat off and run the engine and its circulating fine.
    so bought another aftermarket thermostat same brand and model installed that temp gauge stayed 1/3 drove around the block overheated straight away.
    Any ideas what could be causing this?
    T'ville, QLD
    blocked gallery?
    2T out 4A in....
    radiator was 50% blocked
    replaced the water pump as well
    I'll see tomorrow what the results
    it was the thermostat not opening, even with a new replacement tridon one, tried 2 and wont open at the right temp
  1. A340e Sluggish takeoff? Lockup Solenoid Problem?
    By Z2TT in forum Tech and Conversions
    Last Post: 13-01-2012, 05:10 PM
  2. mz20 eginle light and not running propley ???
    By boardmaniscool in forum Tech and Conversions
    Last Post: 22-02-2009, 01:58 PM
  3. A340E in Cressida solenoid problem?
    By petergoudie in forum Tech and Conversions
    Last Post: 07-06-2008, 01:39 PM
  4. A340e 4th solenoid questions
    By 2jzhilux in forum Tech and Conversions
    Last Post: 04-06-2008, 12:12 PM
  5. hydraulic handbrakes......good read for those into motorsport! ;)
    Last Post: 09-08-2006, 10:55 PM
