Results 1 to 5 of 5
Thread: How to wire up tachometric relay for fuel pump
    Default How to wire up tachometric relay for fuel pump
    Hi all, I am doing a 1JZ swap into a MX83. I am going to use a tachometric relay for the fuel pump.. I got one from a gas fitter but unsure what the pins are..
    I have -
    neg coil (easy)
    gnd neg (easy)
    gas+pos 12v?
    lock off + pos gas?
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Default Re: How to wire up tachometric relay for fuel pump
    hmm no good, mine is only 4 pin totally different. its from a lpg setup, not a commodore.
    hrmm, you may need to get the wiring diagram from the gas fitter dood.
    Does it look like a relay? Just wondering if its a solid state IC type device instead of a relay as it doesn't seem to have enough pins to switch a fuel pump and monitor starter and ign otherwise?
    Um, do you have another car you can test it on? If so, then connect Gnd and -ve Coil and then apply power to one of the two pins, see which way it trips.
  1. fuel pump problem
    By CHB in forum Tech and Conversions
    Last Post: 10-12-2008, 10:09 PM
  2. HELP - how to wire up a fuel pump
    Last Post: 21-06-2007, 01:15 PM
  3. Bigport 4AGE wiring questions
    By Nebuchernezzer in forum Tech and Conversions
    Last Post: 29-08-2006, 07:36 PM
  4. 20v in ke70
    By spoon in forum Tech and Conversions
    Last Post: 02-06-2006, 09:24 PM
  5. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
