Results 1 to 12 of 12
Thread: How to mate GT28RS into 3SGTE ST185
    Jan 2009
    Indonesia
    Default How to mate GT28RS into 3SGTE ST185
    I just bought the bare GT28RS Turbo.
    I'd like to mate it with my 3SGTE engine ST185. Does anybody out there ever done this before ?
    If yes, please advice me what are the things that need to be done ? Your advice really appreciated. Thanks.
    Default Re: How to mate GT28RS into 3SGTE ST185
    You need;
    - Either an exhaust manifold with the correct flange for the GT28RS or fashion an adapter for the stock manifold -> GT28RS exhaust flange.
    - A dump pipe and then a pipe from your dump -> cat
    - Intercooler piping made up to fit the new turbo
    - water lines
    - oil feed lines
    RA23 - Twincharged
    JZZ20 - Daily
    Jan 2009
    Indonesia
    Quote Originally Posted by Kedderz View Post
    You need;
    - water lines
    - oil feed lines
    Ok noted. Let me try it out first and if i come across any problem, I'll let you know again. Thanks.
    Fire + Brimstone
    money would have been better spent on a CT20b or ST215/246 turbofold which both offer similar or better bolt on performance at the same or better pricepoint. don't forget larger injectors + tuning (may need new computer as the ST185 computer has a nasty AFM and crappy boost cut thresholds, no point having a great new turbo if the ECU is holding the party back.)
    Jordan
    A GT28RS will cream a CT26 even with the 'horrid' stock computer.
    Add the the list above for a 185:
    Oil feed adapter
    Sump adapter for drain
    And fabricate a new water elbow for the water lines
    27.90s @ Esses Hillclimb
    Jan 2009
    Indonesia
    Quote Originally Posted by Roundy View Post
    Oil feed adapter
    I have changed to haltech e6x. So what do u think ? Since I have bought the gt28rs turbo, so I think I'd have use
    It anyway. Well thanks a lot for the tip. Let me try first your guaidance and will get back if I face any probs.
    Thanks.
    Jan 2009
    Indonesia
    Quote Originally Posted by jfallen View Post
    Fire + Brimstone
    Jordan
    Jordan,
    I had changed the injector using sard 540cc injector and the haltech e6x. I think year prob solved
    Jul 2009
    Fire + Brimstone
    Jordan
    Jordan the "turbofold" is not backwards compatible so unless the st185 has a gen 4 in it the manifold wont fit. Early 3s had an extra stud that the gen 4 doesnt have!
    Previous ride ST215 Caldina GT-T
    Screamer pipes, quiet when you want them to be and loud when you wanna gate old ladies at the bus stop...
    Jul 2009
    big fan of 6boost manifold and gt3076r for big power
    Quote Originally Posted by Haynesie View Post
    so you take the stud out, if it's in the way...
    In any event with a haltech and big injectors you'll be able to wave goodbye to the AFM and realize the full potential out of that turbo.
    Jordan
    Jul 2009
    Jordan
    If your going to the trouble of a haltech and big injectors why hold it back with a stocko turbo?????? Something from the gt30 series would suit far better.
    Fairly sure the port spacing of the Gen 4 is different to the Gen 2, not just the fact it has an extra stud.
  1. 3sgte rebuild in ST185 advice wanted
    By JJsTA22 in forum Tech and Conversions
    Last Post: 07-08-2009, 04:28 PM
  2. gt28rs turbo=>3sgte st185 modif help
    By davidleonardi in forum Tech and Conversions
    Last Post: 03-08-2009, 02:32 PM
  3. 3sgte and 4agze standard weights?
    By Taxi>Maxi in forum Tech and Conversions
    Last Post: 20-03-2006, 06:55 AM
