Results 1 to 15 of 17
Thread: fuel pump problem
    Perth, WA
    Default fuel pump problem
    i have an external fuel pump problem (not sure which car model it came from). it is similar with VL external pump. it keep on melting the fuel pump fuse 5A but never blow it. there is no short circuit from fuel pump relay all the way to fuel pump +ve terminal.
    the resistance across the +ve and - terminal is 2.5ohm, i've compare with a known functional of same pump it is 5.0ohm.
    it still pumping with good pressure, only problem is it draw too much current and keep on melting the pump fuse.
    any one has experience on this weird problem b4?
    Default Re: fuel pump problem
    If it's got a measurement of 2.5Ohm, then the resistance is too low.
    Likely to be, that the internal winding has short circuited half way through. Hence half the resistance, hence melting the fuse.
    Replace it with a new pump.
    My Dead Supra...
    Quote Originally Posted by ReQuieM in the A70 Thread
    There is some serious talent in this thread for linking anything to fuckin gay sex. Its extraordinary.
    Perth, WA
    if internal winding shorted at half way, the pump should be running slow, hence not able to reach the pressure right? it happens that pressure is ok at preset 40psi.
    Nov 2007
    Are you testing the pump impedance with the pump removed? Bear in mind that 2.5 ohm is almost no resistance and 5 ohm is bugger all more. Even a poor connection to your multimeter can cause this sort of variation in the reading.
    The correct resistance is probably given as a range rather than a value so your 2.5 ohm reading may not mean the pump is buggered.
    Also, I'm quite sure that many of those bosch pumps run 7-8amps (test draw for mercedes benz which use a very similar unit) so if that is the case then it's little wonder that your 5 amp fuse keeps failing. It's difficult not seeing the exact application but it does sound as though your fuse and perhaps circuit cannot support the draw of the pump.
    Junior Member Grease Monkey Cruiser97_80's Avatar
    Tasmania
    If you are melting the fuse and not blowing it check your wiring and connections. A dodgy connection creates heat and also poor wiring and wiring that is too small to carry the load.
    1990 ST185 GT4 3SGTE
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    1998 ST215 GTT 3SGTE
    2008 VDJ200 Sahara
    Perth, WA
    yes 2.5ohm when the pump wiring is disconnected.
    i've being using this pump all the while since Dec last year and it works ok until last week when i heard the pump hissing. when i open my boot and i found out the fuse holder was nearly melted and the fuse inside was swallen/melted. i always have a practice to use thick wires for all the wiring additional wiring in my KE70. by the way, all my added electrical wiring circuit run on relays, so i can isolate it from my stock KE70 wiring.
    i just cannot understand why the bugger fuse does not blow out instead of melting? i just tried to run the pump "manually" the same problem happened. wires get hot but damn fuse was not blown
    errr..
    V=IR
    12=Ix2.5
    I = 12/2.5 = 4.8amps (edited )
    since when car is running it should be say 14-14.5V
    14.5/2.5 = 5.8amps
    no wonder the fuse is melting... it is on the limit fo what the fuse can take.
    surely a 10 amp fuse would be a better idea?
    edit, 10amps for a fuel pump is not unusual. most should be between 5 and 10 or 12 amps...
    edit2: if your wires are getting hot with only 5 amps runnign thru them, then they are either of poor quality, or too small...
    edit 3... 15-20amp capable wire and a 10 amp fuse to begin with....
    one the pump is spinning, doesnt back emf increase the resistance?
    bosch 044's draw 13 amps
    walbro, typically up to 10 amps (might be lucky to only just keep it at 5amps )http://www.autoperformanceengineerin...l/fpspecs.html
    still. 5 amp fuse and cabling is too small for a pump...
    Bogan Hunter Grease Monkey
    Quote Originally Posted by PlacentaJuan
    You'll only get back emf on AC circuits.
    Not DC.
    Perth, WA
    well, during my troubleshooting, i use 20A fuse just to check if it melt and it does!!
    Quote Originally Posted by Gabe
    Not DC.
    i think he means the back emf that exists within the motor, ie eddies that control its final speed
    Nov 2007
    Quote Originally Posted by CHB
    Because the everything else is also likely too small and heats up the fuseholder, wiring etc.
    OC is right although his calculator is broken
    V=IR, at 12 volts current draw is = 12/2.5 = 4.8 amps
    Once it loads up though (and at 14 volts), it's going to draw more current than at free spin so I'd take that into account when you upgrade and use OC's edit number 3, 20amp wiring with 10 amp fuse.
    PS. Measure the current with the engine idling and let us know what it is. Just take out the fuse and bridge the terminals with your multimeter set on it's 20A setting, then start the car and read the draw. Do it straight after start up so that the wiring is still cool and the resistance is at it's lowest.
    thanks.. calculator is fine.. is the brain and fingers connecting to put things on screen that have a problem
    so you are saying the 5amp fuse doesn't melt... and the 20 amp fuse does melt? maybe the 5amp blew very slowly, so it had time to stretch and allow a conductive track of metal still?
    if a 20amp fuse blows on the fuel pump circuit, and the pump is only 2.5ohms, then you have a short circuit somewhere.. cos it should only be pulling 5-6amps
    Perth, WA
    all fuses i tried were melted, be it 5A, 20A and even 30A.
    i'll try to measure the current when i get home..
  1. AE86/Sprinter Fuse Box - Wiring Help
    By xXxPigeonKickerxXx in forum Tech and Conversions
    Last Post: 15-11-2008, 09:46 AM
  2. Dry-sump construction
    By Billzilla in forum Tech and Conversions
    Last Post: 19-10-2007, 01:51 PM
  3. Picking Best Fuel Pump..!
    Last Post: 10-09-2007, 03:15 PM
  4. fuel pump fuse
    By japlish in forum Tech and Conversions
    Last Post: 29-01-2006, 09:32 PM
  5. Mounting fuel pump (intank)
    Last Post: 24-01-2006, 09:49 AM
