Results 1 to 11 of 11
Thread: Where Do These Hoses Go (4AGE)
    Junior Member Grease Monkey Schmitt's Avatar
    Default Where Do These Hoses Go (4AGE)
    Hi guys
    As the title says i am wondering where these hoses/pipes go on the intake.
    If anyone could let me know that would be much appreciated.
    Thanks
    Ben
    Default Re: Where Do These Hoses Go (4AGE)
    the top ones are vacuum leaks that you should plug up (unless you are using a crharcol can, in which case the one that says C or something on it should go to the charcol can)
    the bottome two are coolant hoses, they control the cold idle bypass. if you don't hook these up you will have a high possibly hunting idle and will need to plate off the idle bypass all together.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Plug the blue one, run the yellow to the charcoal canister, plate off the idle up valve then with the bypass on the side of the block run a hose from the inlet to the outlet of it.
    too me it looks like the red arrow is pointing to the power steering idle up connection.
    The water hoses would be pointing down not forward.
    The water hoses are actually plugged up already in that picture there.
    I dont think so, they would be for the air con idle up?
    Ive marked the water hoses with the green arrow
    Actually now i look closer the 2 that are blocked would be for the power steering & the unblocked 1 for air con.
    But to answer your question they are not needed so they all should be blocked.
    Hi
    Sorry to dig this up but what is the best way to block off these hoses. The red one i can buy another of those caps but what about the others. Is there something similar i can buy for them.
    Thanks
    Ben
    The easiest way is to get a little bit of vac tube and put a selftapper into it.
    You can silicon caps in all sizes that look a lot neater
    Or you could plate the idle-up valve off and those fittings will disappear with it.
    Last Post: 17-06-2008, 08:53 PM
  2. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
  3. 4age engine mounts
    By duff_boy in forum Tech and Conversions
    Last Post: 03-03-2006, 12:35 AM
  4. 4AGE cooling system - an observation
    By roadsailing in forum Tech and Conversions
    Last Post: 18-12-2005, 11:01 AM
  5. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
