Results 1 to 4 of 4
Thread: rt 142 gearbox mount
    Nov 2008
    Default rt 142 gearbox mount
    Is there a trick to bolting a new gearbox mount to the gearbox ? The box is still in the car.
    I've an rt142 wagon and the new (non genuine) mount appears too narrow, but, I imagined with a little force it would squeeze up far enough to line up the 4 bolts that hold it to the box.
    Problem is when I attempted to squeeze it on with the aid of the hydraulic jack the box just lifted up meaning I couldn't amount any real pressure.
    I thought of putting a block of wood between the gearbox and the car floor, but, I'm thinking with the amount of pressure I might need to get this mount onto the box, the block of wood might put a nice dent in my floor.
    Is there a trick to getting it on ? or, would a genuine toyota mount slip right on ?
    Any help appreciated.
    Trevor
    Default Re: rt 142 gearbox mount
    The only thing I can say, is that I have had exactly the same drama as you. Persistence, sweat and many curse words are normally what gets the new mount on in the end. Seeing as this problem has appeared for me on the W50, W55, W58, A40 and A40D transmissions, which all share the same mount, I would hazard a guess the aftermarket mounts aren't quite made right.
    If you have a die grinding burr or a round file, try opening out the holes slightly. Eventually they do go on.
    Nov 2008
    Thanks for the Reply Owen. Something that should be so simple is so damn annoying really. I'm thinking I'll either get a mechanic to put it on or go get a genuine part if it'll just slip on and do it myself. Either way it'll cost about the same I imagine. Thanks again.
    Can't comment on whether a genuine rubber will slip on or not unfortunately... must try that one day (maybe with the 3S's gearbox)
  1. Massive vibration/shaking after supra gearbox swap
    By DrNick in forum Tech and Conversions
    Last Post: 28-04-2009, 05:22 PM
  2. w58 gearbox mount
    Last Post: 30-07-2008, 10:06 PM
  3. Engine mount dilema
    Last Post: 07-09-2006, 11:21 AM
