Results 1 to 15 of 19
Thread: Massive vibration/shaking after supra gearbox swap
    Junior Member Backyard Mechanic DrNick's Avatar
    May 2008
    Default Massive vibration/shaking after supra gearbox swap
    The car is a 1995 JZA80 SZR Supra, originally with the 5 speed W58 transmission.
    I have replaced the following parts
    R154 gearbox swap
    Rear main seal
    1JZ Flywheel (secondhand flywheel, was machined before use)
    ARP fasteners
    XTreme 6 puck clutch kit (with new pilot & throwout bearings)
    JZZ30 front driveshaft
    OEM gearbox crossmember and mount
    Everything looked promising, started up the car and there is a massive vibration sitting there at idle. It is mostly between 1-2K rpm but I drove the car and it does it all the way through the rev range. The vibration is the same whether it is neutral or driving.
    The gearbox itself is not noisy or clunky and the clutch feels very smooth.
    I have since replaced the engine mounts as they looked a bit flat, but it made zero difference. I also just looked through the gearbox inspection plates with the engine running and there is nothing visibly wobbling etc. Same goes for the engine, everything seems smooth. In fact if you put your hand on the engine it doesnt feel shaky like it does when you sit in the car.
    It's pretty disheartening as the project has taken a few weeks and now the car is worse than when we started! Has anyone encountered something like this before? Please tell me what I am missing here.
    Default Re: Massive vibration/shaking after supra gearbox swap
    id be pulling the box back off and checking pressure plate/flywheel bolts, as its something rotating making that vibration
    thats if everything external looks fine,
    Quote Originally Posted by DrNick
    R154 gearbox swap
    Any of these could be out of balance. Chances of the box being out of balance would be slimmer than a bee's dick, generally would only happen if you knocked some teeth off, have rooter bearings, shafts etc.
    By driveshaft im guessing you mean front section of the tailshaft. I'd say its probably that. If its not this then i'd be looking at the clutch or flywheel.
    May 2008
    Quote Originally Posted by LeeRoy
    Yes I mean the front half of the shaft is from the JZZ30, the rear half is the original one I had on there before. I thought this was a bit suspect before, but the vibration is there when the car is in neutral so those shafts would be disengaged.
    Victoria, Mt Macedon
    If it still vibrates in neutral, then you've narrowed it down to input shaft, clutch or flywheel (or maybe the motor itself but I think that's unlikely).
    If it still vibrates when the clutch is pushed in then you've narrowed it down to flywheel and clutch pressure plate.
    Whatever the case I think you'll have to drop the box again and take a good look at it.
    Hen
    Gearwhore. Backyard Mechanic
    Oct 2008
    I'd put money on clutch.
    The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
    Tallahassee, FL USofA
    Trans. hitting the tunnel or cross-member if it isn't the clutch or flywheel.
    Nov 2007
    Gearbox mount maybe?
    Everything looked promising, started up the car and there is a massive vibration sitting there at idle. .
    this pretty much rules out anything exernal as nothing else will be moving....most likely internal, clutch/fly
    Apr 2007
    I would put my money on the clutch pressure plate being the cause ... I fitted a clutch years ago, that had a massive vibration as well when the car was running, removed clutch again & inspected, found the pressure plate main face ( clamping face ) was actually off centre, ( slightly ) i suspect the pressure plate had been dropped as some of the side tension straps were actually slightly bent ..
    Fitted up another new pressure plate & all good again ..
    Obviously check all that when you pull it out & if in doubt get the pressure plate & the flywheel etc balanced .. But get them balanced individually though ..
    Rob ..
    do u get clutch shudder on takeoff? if so it is probably not aligned properly
    otherwise flywheel balance
    it wont be tailshaft it it does it whilst sitting still....
    May 2008
    The car shakes so much its actually hard to tell if i'm getting clutch shudder! Although I would be inclined to say yes there is a bit, but not every time I take off. I thought that was consistent with the harsher puck style clutch plate though. I'm going to go and take another look at it this morning, looks like either way the box has to come off again. Thanks for the tips so far, I will keep you posted
    Jun 2008
    After you take the pressure plate off put a dial gauge on the flywheel. It's possible there is a piece of dirt under the flange face that bolts onto the crank.
    May 2008
    Well I'm taking a break from it and the car is locked up in my mates shop while he is away on holiday. Will tackle it in a week or two.
    However, when I last saw it I had a look at my old flywheel and that had holes drilled in it for balancing purposes. Please tell me that the flywheel is not balanced with the crankshaft.. That would be disastrous as we didn't mark the position of the flywheel/crank flange when removing it.
    Jun 2008
    My understanding is that manufacturers balance the crank with the flywheel and pressure plate fitted. The pistons & conrods are not fitted though as they match the weights on the production line so the weights are the same.
    However, when you fit a new pressure plate several years later it can't be balanced to the crank. Similarly if you buy a new flywheel. I suspect that the vehicle manufacturer only wants to balance everything once rather than the individual bits separately whereas with aftermarket parts the cost of the individual balancing is included in the sale price.
    Whilst it's better to fit all the original parts back on the same way they came off I doubt if it would make 'massive' differences in vibration as you describe but I could imagine it might be detectable.
  1. Verifying a w58 gearbox
  2. AE86 Gearbox Conversion Options
    Last Post: 20-03-2006, 01:30 AM
  3. W58 Supra gearbox Input spline count info
    By Esteban in forum Tech and Conversions
    Last Post: 29-12-2005, 12:11 AM
