Results 16 to 20 of 20
Thread: Coilover trouble
    Junior Member Grease Monkey ta22 3tgte's Avatar
    Sep 2008
    Default Re: Coilover trouble
    Yeah, I must have fluked getting the right gland nut supplied with my strut inserts, which saved some hassle. But machining the centre of the original nut would have the same outcome. Mine is fine, so I don't think you'll have any dramas.
    Cheers Brendan
    Quote Originally Posted by roadkill View Post
    i had the same sort of issue with cutting the struts down. Though for me i had cut them down before i'd even ordered the inserts.
    bEn
    my kyb inserts came with both types of gland nut; one coarse one fine.
    why you'd cut your struts apart without dummying it all up and measuring first, I have no idea.
    oh,that's right I read it on the internet it must be unequivocably true
    i pulled three hundred rocks from the land to build my house
    i walked quiet through the forest like a tiny quiet forest mouse
    the oceans will rise
    please stand by the shore
    ummmm, that'd be because it had been done many times before with success!. At the time i didn't have a celica for the setup to go into but i had the strut, springs, sleeve, rotors and calipers. The only thing i didn't have was the strut insert. I decided there was no point in spending another 280 on the setup when i didn't have a car for it to go into but wanted to get as much of it done so when i got a car for it to go into i didn't have to muck around doing it then.
    :-P
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
    the point i am making is that whatever your reasoning, cutting before measuring for yourself did your head in later.
    Quote Originally Posted by SeptemberSquall View Post
    Huh, where did i say i didn't measure them? Everything was measured, taken off many other peoples results which were consistant? If anything it didn't do my head in. It all worked out perfect. No spacer needed. Would've needed to machine down the nut regardless to make it fit over the strut insert...............
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  1. Replies: 8
    Last Post: 18-09-2009, 01:21 PM
  2. Thoughts on sleeve coilover kits (MA61)
    By VA61DETT in forum Tech and Conversions
    Last Post: 18-12-2008, 05:55 PM
  3. Guide: Coilover Conversion
    Last Post: 18-03-2007, 08:45 AM
  4. coilover sleeve lenght?
    By slide86 in forum Tech and Conversions
    Last Post: 18-01-2006, 06:18 AM
