Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: Thin Powerful Thermo Fan Needed!
    Default Thin Powerful Thermo Fan Needed!
    Hi guys,
    just wondering where i could possibly grab myself the thinnest yet most powerful thermo fan? Any recommendations?
    How much am i up for?
    Location - Sydney
    Default Re: Thin Powerful Thermo Fan Needed!
    you want the applest orange?
    how thin does it have to be?
    can you mount a fan on the front of the radiator instead of the rear (or the other way around)
    if you need a crazy powerul radiator fan, then you probably need a better radiator.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    The thinnest one available...not much room to play with...
    Cant mount the fan on the front as the air con condensor is there...
    Rather change the fan...not the radiator...
    autobarn do the super duper thin ones.
    flows pretty damn good on my car and mine looks just like the autobarn ones.
    they go for 120 i think for a 10"
    if i was you, go to 2 smaller ones, rather than one big one. you'll get more airflow over a bigger area
    So did you buy yours from autobarn or does it just look similar to the ones they sell?
    I take it that 10" is the smallest one available?
    I hear Davies Craig is probably the best on the market? Is it the thinnest?
    mine came with the car
    id say it is an autobarn one
    i think they come in 8"
    not sure. go in and have a look
    If AutoBarn is anything like the supercheap etc, avoid it. Check for 'made in china' labling. Davies Craig are absolutely awesome, and Australian made. I can get the 10" for about $95, not sure if that's a standard price or not, but if you're that keen I can freight them to you. First thing: if it's getting hot, get rid of the AC condensor, it kills airflow to the radiator. What's your car and application? Have you run a good cooling flush and good coolant thru the car?
    RM.
    Not just a regular Backyard Mechanic ProjectSleeper's Avatar
    Step 1. - Measure EXACTLY what space you have available.. (Diameter and Depth)
    Step 2. - Jump onto www.daviescraig.com.au and check out their specs...
    Step 3. - Purchase correct Fan/s
    I am running twin DCSL14's on my Cressida and they work very well..
    How much for 2 x DSLX10? (50mm wide compared to the 64mm of the DSL10)
    Its fine wen moving....but wen stationary for like 5-10minutes in the afternoon, the needle likes to venture past half way...otherwise it is well behaved at below half way...(mind you, there is only ONE fan on it now - some 10" fan with 1/4 of the shroud angle grinded to clear the dump pipe. When tested against the stock thermo fan, it was nowhere near as powerful)
    Project Sleeper, where did you purchase your fans from and for how much?
    That's not a real problem man, as long as it doesn't go into or close to the red, it's not a huge problem. What's your application?
    RM
    I'm in the same boat.... I need a dam slim fan i got no room either side of my radiator. I heard honda's has some really slim and powerful fans, i'm going to check it out on sat (today)
    just hack some up
    my thermo is a mix of supercheap 14" thermo fan blades and a cut down 14" davies craig body, wasnt a cheap exersize, but its only 30 somthing mm thick
    KE38 - 2TG
    MS65 - 1UZ
    I understand you can cut the body...but i hear that the shrouding is a pretty main helping factor for efficient cooling...also...for my right hand side application, its not so much the shrouding im worried about, its the motor that wont clear it...so hopefully 50mm is enough to clear it...not only that..but i hear that cheaper fan/motors arent as fast/powerful as the davies craig ones...
    They're not. And they aren't as reliable or quiet either...you get what you pay for. If you want china crap, by all means buy it, if you want quality, look for something australian made.
    RM.
  1. Thermo fans and engine temps
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 15-04-2006, 07:56 AM
