Results 1 to 12 of 12
Thread: hilux suspension questions???
    Default hilux suspension questions???
    Hey all, does anyone know what year 4x4 hilux has front and rear leaf springs? i know most have torsion bar front, rear leaf...but at some stage they had front and rear leafs didnt they?
    Blake
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
    wa
    Default Re: hilux suspension questions???
    If it has a solid axle front end it has leaf springs
    If it is IFS it will have torsion bars
    Basically most hiluxs up to about 95-96 with no IFS
    Thanks mate, it didnt deviate between dual cabs and single cabs did it? im looking for something around 82-90 dual cab model to lift and fit 1uz for offroad....
    they only went ifs 1997+
    so most pre 1997 units will have a live axle and leaves in the front.
    Forum Contributor Domestic Engineer
    Quote Originally Posted by TooF View Post
    Correct.
    All lux's up to 96 had live axle / leaf combo. 97 can go either way depending on early or late, and model type. 97 / 98 brought in the new shape, and all went IFS.
    All single and dual cabs didn't change to IFS until the new shape in late 97, but the extra cabs are the ones which got the IFS earlier, though not sure on date.
    Someone else may have to confirm when it comes to the 4 runners, as i think they got the IFS sooner than the lux's.
    I would suggest the model that ran from 89 to 96, as they are a bit nicer / have better components than the earlier models, and easier to find in SR5 trim with the LSD. They are a bit pricier though, up to about 10k for a good reasonably low k diesel one, with petrols being significantly cheaper. Ones with munted engines are still quite cheap though.
    Junior Member Backyard Mechanic {Mr Crabs}'s Avatar
    Apr 2007
    SR5 89 on were IFS.
    Cheers Case
    i think surf's were all ifs too?
    just looking at an older one with leaves to lift the bejus out of and fit a blown 1uz into...
    yes surfs were ifs although i have an odd feeling you could get ifs with coils in the front of surfs as opposed to the ifs with torsion bars in the front of luxs
    confusing...so many farken variations!!
    hahah you havent even got one yet !!!
    start comparing how many different bloody engine variations they got. currently we get 3 different engines in the new lux. (4cyl petrol,. 4cyl diesel, 6 petrol) then add three cabin combos onto that, plus tray options,
    actually go back a few years we got four, 4p, 6p, 4d , 4td ( and the diesel ones were different family not just na/t of the same block)
    the list keeps getting bigger.
    i wish they still just chucked live axles in the front or gave an option. ive got a 98 ifs and would love live front end. i guess ill just have to get a cruiser
    sir Grease Monkey
    tasmania
    from 89 to 96 only the sr5 had ifs all others were leaf sprung. cheers big wad
    New Zealand
    look at the model numbers
    ln61 = IFS
    ln107 = IFS (i think what you are calling SR5s)
    ln60 = leaf front
    ln106 = leaf front
    then after that (ln167, kzn165) they all IFS
    please, no more PMs!
  1. Trailing arm rear suspension pros/cons?
    By Brett in forum Tech and Conversions
    Last Post: 02-06-2008, 03:48 PM
  2. Hilux Diff (yes more!) Questions
    By medwin46 in forum Tech and Conversions
    Last Post: 16-01-2008, 12:10 PM
  3. 18RGU to Hilux engine swap questions
    By smokem1 in forum Tech and Conversions
    Last Post: 27-11-2007, 12:06 PM
  4. Suspension for dummies
    Last Post: 13-09-2007, 07:38 PM
  5. Suspension Questions - with pic
    By Pearce in forum Tech and Conversions
    Last Post: 23-11-2005, 06:57 AM
