Results 1 to 11 of 11
Thread: 18RGU to Hilux engine swap questions
    Forum Member Grease Monkey smokem1's Avatar
    Northern Territory
    Default 18RGU to Hilux engine swap questions
    Hi
    Finally started to put my 18RGU in my 1980 2WD hilux (RN41) . For those who believe its just a straight swap it's not, a little bit of "customisation" is required. The engine and gearbox fit no problems. The pacemaker extractors had to be shortened 30mm or so to clear the torsion bar on the exhaust side.
    The drama im having at the moment is that once the manifold, spacers, carby's and air filters are bolted up they impede on the Brake booster by about 20-50mm or there abouts. I am using a short manifold and like one inch tall K&N airfilters to give as much space as possible. The airfilters almost hit the bar that go's from the steering wheel to the steering box (i forget the terminology ) but it looks like there should be enough clearance.
    Anyways so i'm considering using a remote brake booster? or seeing if anyone on here maybe knows of another smaller brake booster from another toyota or other car that might be able to be substituted without too much hassle?
    Any thoughts or suggestions are welcome.
    Daniel
    Ballarat Vic
    Default Re: 18RGU to Hilux engine swap questions
    Are you using factory spacers or unifilter flexible mounts?
    The flexible mounts will save you about 30mm.
    Roscos
    Northern Territory
    Quote Originally Posted by Roscos
    Roscos
    Thanks, Im using the factory black (bakelite?) spacers, they are approx. 10mm thick. Ive never heard of unifilter flexible mounts lol can you give me any more info. on them please so i can suss em out? (I'll google it anyway)
    Ballarat Vic
    I think they are made by unifilter and they are a metal gasket fitted with a rubber ring on the opening of the manifold and the throat of the carb. It means that the carbys are flexible and not solid mounted as per factory. You also need to buy the mounting nuts as well as they are rubber backed.
    Go find a speed shop that sells that kind of stuff and ask for flexible gaskets for side draught webers or solexes. Not sure of price, haven't bought them for a long time.
    Roscos
    Northern Territory
    Roscos
    thanks Roscos i will check them out... +rep for ya
    I dont think it will save that much clearence (although i'm not sure of the size of the original spacer) but yes Redline make softmounts for solex/webers, they look like this:
    Mr Shabadoo.
    Daily JZX100
    Northern Territory
    Quote Originally Posted by joey
    thanks but yeah i cant see those softmounts making any difference, may have to try and remount my brake booster slightly to allow for clearance.
    still welcoming suggestions
    Ballarat Vic
    Well there is only one way to find out, put the motor in without the carbys and then mount the carbys on with either gasket and work it out from there.
    Whats it doing, hitting the booster or the threads off the booster?
    If its the threads, cut it off to where the bolt ends so there is no thread showing.
    l had the same problem with a TA23 and that what we did but l was running ram tubes.
    Roscos
    Northern Territory
    roscos yeah had a look last nite these rubber mounted gaskets arnt going to work the airfilter will stll hit the booster. The airfilter is also hitting the steering rod thingy aswell. I'm thinkin of switching to ram tubes too, i think that will solve my problem.
    I had to put 5omm spacers to raise the cab to fit in a 5lt V8. Made heaps more room.Maybe this would help with your clearance problems. Not hard to do and looks better too.
    Ballarat Vic
    Check the size of the booster, l think HiLux booster were fairly big in diameter compered to early model celica boosters. Go find an RA40 booster and change it and you might have to think about Borg-warner paper filters, you can alway get foam elements for them.
    As for steering check for later models, you might be able to change things.
    Roscos
  1. st162 engine swap
    By buztoy in forum Tech and Conversions
    Last Post: 18-05-2007, 05:21 PM
  2. What Engine Will go?? Hilux 1997 model!!
    By mgfe in forum Tech and Conversions
    Last Post: 23-09-2006, 04:13 PM
  3. Engine Swap for mz10
    By chefy83 in forum Tech and Conversions
    Last Post: 25-07-2006, 04:31 PM
  4. rn40 hilux engine and gearbox questions
    By vanman in forum Tech and Conversions
    Last Post: 09-04-2006, 06:07 PM
  5. Supercharge a 2.2 4y (na) motor or engine swap
    By steve_t647 in forum Tech and Conversions
    Last Post: 22-11-2005, 05:22 PM
