Page 1 of 3 123 LastLast
Results 1 to 15 of 36
Thread: Custom Sumps - Ideas and Inspiration
    Default Custom Sumps - Ideas and Inspiration
    Ok, so maybe this wont be as popular as the quad schlottle body thread, but i need some inspiration for my new sump. Currently thinking a fairly standard winged jobbie with internal flaps for oil restriction. Kind of like this one:
    and
    Anyone have better suggestions, or advice?
    Penrith BC
    Default Re: Custom Sumps - Ideas and Inspiration
    windage tray
    skirt around oil pickup
    sump flaps and install fixed baffles
    ../delete/ban
    tech moderator
    Penrith BC
    note the uni directional pressing
    ../delete/ban
    tech moderator
    4A has a seperate windage tray which is sandwiched between sump and block.
    However, with that last picture you have posted it looks like they have installed a hinge in there for some reason and then welded it down.
    Any reasons?
    Penrith BC
    its not welded down, its free to swing. note that it swings forwards - this is a drag engine sump - lots of g's under launch - trap door is for preventing slosh to the rear of the sump.
    edit - im reassesing trap doors...
    ../delete/ban
    tech moderator
    Oh i see now, i thought that the lines across the bottom of the trapdoor were from where they had bent the metal. Rather it is two seperate pieces.
    Understand now.
    Why are you re-assessing trap doors?
    Penrith BC
    i initially disliked them...
    but reading some stuff just now whilst looking for those pics, im beginning to be sold on their specfic use in winged and otherwise increased volume sumps. *shrugs* guess im just used to fixed baffles
    id be wary of gunk and resin making them stick shut though
    also, if youre playing with sumps, consider how youre ventilating it:
    http://www.v-eight.com/tech_forum/viewtopic.php?t=38
    cheers mate
    ed
    ../delete/ban
    tech moderator
    Far out, you post a hell of a lot of stuff on v-eight. +rep for you, when i can find enough other people worthy of having rep.
    Robots! dancing robots! Domestic Engineer gearb0x's Avatar
    After talking to my head guy about his sump designs he highly recomends the pressed steel mesh, his reasons are that as oil flings off the crank in all directions, it hits the mesh and it directs it down to the sump
    Dry Sump.
    Lock thread!
    Friends
    Junior Member Backyard Mechanic Dimitri's Avatar
    have you seen the ARE sump for sr20s? the pick up "swings".the idea is it will move as the car leans, thus following the oil.
    i dont know about moving parts in the oil pickup, but its a noval idea.
    a few tips from a book i just finished reading:
    make sure the pickup is between 9.525 and 6.35mm from the sump floor, to prevent surge and not restrict the pickup.
    it also suggests a horizontal baffle with a hole cut in the middle just big enough for the pickup to go through (so you can fit the sump) the edges of the hole should be flared/funneled down to allow oil to go into the sump and prevent it coming up the sides.
    just drysump it
    you have vented both cam covers on your race engine haven't you? you might be able to run two inlet covers for that JDM tuner look (i need to confirm you can do this on smallports)
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    Is there any reason why the book quotes such precise figures for the distance between the pick up and the sump floor? just seems a bit wierd :S
    theyer conversion from imperial 6.35mm is 1/4" ect..
    dimitri is on the money, should have just written them in imperial i guess.
    www.vicdrift.com
