linden (roadrunner fabrications)...........or the "the real roadrunner" on these forums........cant recomend that homo enuf!
he's seriously very good.
Hi guys,
I have a AE93 GTi corolla with a 4AGTE.
The current manifold sits the turbo way to low and as a result i cant get a good drain setup. the manifold looks like a custom job (professional or backyard not sure but its definetly isnt a ebay manifold )
What id like to do is modify it to sit the turbo higher in the bay, who would you recomend for the job ( DIY'er that has EXP welcome) and what would i expect to pay?
Alternatively, would it be easier/more cost effective to get a new manifold made and what is the usual going rate for this? and who would i see?
Dave
91 4AGZE SX Hatch.
98.8kw@ wheels (Standard Boost)
15.01@89MPH (Standard Boost )
Remember you may need to modify the dump pipe depending how much higher you move the Turbo.
It sounds like you want to move your turbo a fair bit, so it may be easier=cheaper to just plumb in a little sump and diaphgram pump with a return, which would be much easier than redoing manifold/dump/intake pipe
GA23(never finished-now with cracked block) JZX83 (Tyre eater) 3sgte AE86. by now i should know better.
