Results 16 to 21 of 21
Thread: SARD Torque Control valve, useless?
    Default Re: SARD Torque Control valve, useless?
    Quote Originally Posted by Cuzzo
    How could more back pressure help build boost?
    Wouldnt it then slow down the exhaust wheel?
    I don't know. But refer here
    Explain the lines crossing over...
    Jun 2007
    Quote Originally Posted by The Last Streetfighter
    Putting a 2.5" restrictor in the system will cause exhaust back-pressure to be higher and therefore the wastegate to seal better under low Boost conditions.
    Nov 2007
    From that dyno graph I see that there is more power from the restrictor down low, so the Torque control valve may be beneficial after all.
    Quote Originally Posted by abently
    Boost pressure is higher lower in the curve though, its not about the wastegate sealing better. If your waste gate need backpressure to seal then you have issues with the wastegate controller.
    Nov 2007
    So was the SARD rep correct in the email he sent me back?
    Jun 2007
    As mentioned in that link....
    To be technically correct I would say without MAF datalogging of both dyno runs then that graph is completely useless.
    Common sense says along with hundreds of back to back tests says putting in a restrictor does not help low end torque...
    If you want to find that out for yourself, feel free to.
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 06:11 PM
  2. What ECU do you use?
    Last Post: 06-12-2007, 10:42 AM
  3. Autronic SMC boost control help
    Last Post: 27-08-2006, 10:16 PM
  4. Replies: 9
    Last Post: 21-03-2006, 10:41 AM
