Results 1 to 4 of 4
Thread: ra23 18rc to 18rgeu: Fuel Pump
    Nov 2007
    Default ra23 18rc to 18rgeu: Fuel Pump
    What could be used for an 18rgeu?
    Eltham vic
    Default Re: ra23 18rc to 18rgeu: Fuel Pump
    it depends if you are running a surge tank and want to run an in tank pump with a lifting pump
    i am about to put an 18rgeu mtr in my 28 , i have a choice of a pump from a ra45 gt or a vn v8 commodore pump , surprisingly they are very similar
    ian
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    VL turbo are cheap and reliable - see ebay,
    last three cost $10+post
    is it actually going to be efi??? If it is going to be carbied you can just use the normal 18r pump that bolts on the side of the block BUT BUT BUT the pump drive shaft (the shaft that drives the fuel pump) doesn't have the lobe provision for a mechanical pump if it is a genuine 18rgeu. Easy to check and easy to use if going carbs - take off blankinng plate and see if the lobe is there. Plate is on drivers side, roughly 5cmx5cm with two bolts holding it on. It is the smaller of the two plates on the side.
    bEn
    FJ40 landcruiser
    HJ47 landcruiser
    FJ55 Landcruiser
    MS65 Crown
  1. Replies: 38
    Last Post: 02-06-2009, 01:55 AM
  2. 1JZ Fuel Pressure Regulator Limits
    By beasht in forum Tech and Conversions
    Last Post: 19-04-2008, 05:17 PM
  3. Diagnosing a dying fuel pump
    Last Post: 01-04-2008, 05:45 PM
  4. Mounting fuel pump (intank)
    Last Post: 24-01-2006, 09:49 AM
  5. Replies: 1
