i have a mate here in qld who has had some billet ones made up. i can give you his email if you like
.... theyre not cheap.
ok yes it wouldnt work..
I pulled my diff out again and had a good look.. it is still a 23spline center and it has never been used. BUT the sprinter 23spline axles won't fit cause they are a bit too small.
Different toyota 23 spline axle and now Im going to try it. Its the same diameter as the larger one in the pics I posted earlier.
isnt ra28 kouki??? i think some1 said this too me???
i have 1 bent and 1 straight...will measure tomorow or tonite.
pm me tomorow morning to remind me (i have a habit of forgetting this stuff)
or email me [email protected]
Black Betty >HERE!<
(\__/)
Guys are chopping up stuff for 9 inchers all the time. Can't ne that hard to find someone to re do some axles for you. Take the opportunity to have them done right and future proof.
Spline ****ting by a general machinist = $$$$$$. I had a gear made, std straight cuts, no fancy tooling or anything. By the time it was cut, dressed and treated $650-.
Is there a different et of sun gears that will fit to suit more readily available axles?
Friends
this what you are after?
http://page7.auctions.yahoo.co.jp/jp/auction/g42147875
what do axles weigh (apart from a shitload)???
awesome.. disc brake rear kouki axles. with bearings the size of king kong.
yeah Im all god now I got my car running.
I used tarago Axles. they fit and my car is driving. (E series)
E series?! ww .. wouldnt have thought it.
but if it works it works.![]()
Black Betty >HERE!<
(\__/)
yeah when I first hit the wreckers I was looking for something with a another tooth or 2 on the spline. BUT then I saw the club4ag.com tech section where the guy has a vernier caliper on the kouki axle and it was still 23 tooth spline. SO I took my calipers and went looking again. found that the e-series is the same axles IDENTICAL EVERYTHING bnut the spline was 25.3mm diameter. Not 24mm. YEAH!!!
I think i have what you is looking for.... 25.3mm dia'... 23 spline... 4 x 114.3 PCD... axle face to end spline = 690mm... outer of bearing to end spline = 630mm... from a 1410mm wide diff... axle bearing dia' 72mm....
in Adelaide.. send a PM..
Project: '82, GA61 XX
Welcome to last year....
Beige.... The new Black!!!
Plus he already got the parts...
Double the pointlessness!!!
Given the rarity if I was him I'd want some spares.
mental neg rep for not thinking for all joo
Friends
Cool .. it was late last knight .. But looks like i was latter ....Originally Posted by Lambolica
PS. any way it make's up for all my old thread's people dig up....
I'm very interested in this, as I have a kuoki T series LSD at home and E series Tarago axle splines DO NOT fit it.
I am sure it is Kouki T. An RA60 axle fits, but is loose in the splines, an AE95 axle fits snugly and an E series axle does not fit.
Can anyone shed any further light?
Originally Posted by AZA510
"I'm very interested in this, as I have a kuoki T series LSD at home and E series Tarago axle splines DO NOT fit it.
Can anyone shed any further light?"
WTF is going on..???
one says tarago fits & the othe says they don't..???
I have an "E" axle.... 25.3mm dia'... 23 spline... 4 x 114.3 PCD... axle face to end spline = 690mm... outer of bearing to end spline = 630mm... from a 1410mm wide diff... axle bearing dia' 72mm....
Q:- is this the right axle for this..??
