Results 16 to 30 of 49
Thread: Desperate Need Of Kouki Axles
    Low rep 1st year Apprentice
    Default Re: Desprite Need Of Kouki Axles
    ok yes it wouldnt work..
    I pulled my diff out again and had a good look.. it is still a 23spline center and it has never been used. BUT the sprinter 23spline axles won't fit cause they are a bit too small.
    Different toyota 23 spline axle and now Im going to try it. Its the same diameter as the larger one in the pics I posted earlier.
    Junior Member Backyard Mechanic Dimitri's Avatar
    i have a mate here in qld who has had some billet ones made up. i can give you his email if you like
    .... theyre not cheap.
    isnt ra28 kouki??? i think some1 said this too me???
    i have 1 bent and 1 straight...will measure tomorow or tonite.
    pm me tomorow morning to remind me (i have a habit of forgetting this stuff)
    or email me [email protected]
    Black Betty >HERE!<
    (\__/)
    Guys are chopping up stuff for 9 inchers all the time. Can't ne that hard to find someone to re do some axles for you. Take the opportunity to have them done right and future proof.
    Spline ****ting by a general machinist = $$$$$$. I had a gear made, std straight cuts, no fancy tooling or anything. By the time it was cut, dressed and treated $650-.
    Is there a different et of sun gears that will fit to suit more readily available axles?
    Friends
    this what you are after?
    http://page7.auctions.yahoo.co.jp/jp/auction/g42147875
    what do axles weigh (apart from a shitload)???
    awesome.. disc brake rear kouki axles. with bearings the size of king kong.
    yeah Im all god now I got my car running.
    I used tarago Axles. they fit and my car is driving. (E series)
    E series?! w w .. wouldnt have thought it.
    but if it works it works.
    Black Betty >HERE!<
    (\__/)
    yeah when I first hit the wreckers I was looking for something with a another tooth or 2 on the spline. BUT then I saw the club4ag.com tech section where the guy has a vernier caliper on the kouki axle and it was still 23 tooth spline. SO I took my calipers and went looking again. found that the e-series is the same axles IDENTICAL EVERYTHING bnut the spline was 25.3mm diameter. Not 24mm. YEAH!!!
    south austraila
    I think i have what you is looking for.... 25.3mm dia'... 23 spline... 4 x 114.3 PCD... axle face to end spline = 690mm... outer of bearing to end spline = 630mm... from a 1410mm wide diff... axle bearing dia' 72mm....
    in Adelaide.. send a PM..
    Project: '82, GA61 XX
    Welcome to last year....
    Beige.... The new Black!!!
    Zub Zub Domestic Engineer Gavatron's Avatar
    Adelaide, SA
    Plus he already got the parts...
    Double the pointlessness!!!
    Given the rarity if I was him I'd want some spares.
    mental neg rep for not thinking for all joo
    Friends
    south austraila
    Quote Originally Posted by Lambolica
    Cool .. it was late last knight .. But looks like i was latter ....
    PS. any way it make's up for all my old thread's people dig up....
    Victoria, Mt Macedon
    I'm very interested in this, as I have a kuoki T series LSD at home and E series Tarago axle splines DO NOT fit it.
    I am sure it is Kouki T. An RA60 axle fits, but is loose in the splines, an AE95 axle fits snugly and an E series axle does not fit.
    Can anyone shed any further light?
    south austraila
    Quote Originally Posted by AZA510
    "I'm very interested in this, as I have a kuoki T series LSD at home and E series Tarago axle splines DO NOT fit it.
    Can anyone shed any further light?"
    WTF is going on..???
    one says tarago fits & the othe says they don't..???
    I have an "E" axle.... 25.3mm dia'... 23 spline... 4 x 114.3 PCD... axle face to end spline = 690mm... outer of bearing to end spline = 630mm... from a 1410mm wide diff... axle bearing dia' 72mm....
    Q:- is this the right axle for this..??
  1. changing rear axles
    By turbo ke20 in forum Tech and Conversions
    Last Post: 25-03-2006, 01:46 PM
  2. AW11-AE92 axles
    By Grippy in forum Tech and Conversions
    Last Post: 10-01-2006, 08:35 AM
