Results 16 to 21 of 21
Thread: 1JZ smoky
    Default Re: 1JZ smoky
    Quote Originally Posted by 1JZ~lux View Post
    The new PCV from Toyota is a bit straighter and is meant to fix the blow by problem the old 1JZs had. Made a bit of a difference in mine. I don't know how much smoke it's blowing now, but there was now oil in the front turbo's inlet pipe this time and the dip stick doesn't lift as much as it used to.
    You wouldn't happen to have the part number for this would you?
    Sorry guys haven't been on for ages.... ended up taking the car to someone it was the turbo oil seals
    1JZ 1989 MZ20 Soarer - 3 week conversion all by myself
    200 rwhp 1977 MX36 Cressida wagon - off the road and needs a new home
    1986 Tarago campervan conversion on the go.
    2011 Toyota Aurion
    Quote Originally Posted by yotamotion View Post
    seems i was subscribed to this.. mine too ended up being busted turdbro oil seals
    Jul 2007
    haha i have the exact same symptoms. no points for guessing what it might be
    Junior Member Automotive Encyclopaedia Hengsta's Avatar
    Ok guys i got pretty much the same problem but on a 2JZ?
    Blue smoke, some times it smokes alot sometimes it doesnt smoke at all. Its running true twin mode with rear housing mod. Turbos looked absolutly fine when i put the turbos on.
    Would running 550cc injectors with stock ecu (NOT TUNED) + 023 intank pump got to do with anything? I notice the car is misfiring alot and i mean ALOT. When it nearly hits full boost its shutters. One thing i havent changed is the spark plugs in them when i put the engine in which i totally forgot to?
    Any help much appreciated!
    -Sleeper 2J + R154 X83
    -GQ 93 Mav, 4.2 Diesel, 35" BFG KM2's, 4" lift, 3" Exhaust, Front Locked, Rear shimmed, Sliders, IPF foggies, UHF, 2871R and Intercooled.
    I would think anything fuel or ignition related would give you black smoke, not oil smoke
    My turbos still looked fine when i pulled them off (rear one still usable) - but there was oil around in the pipes and in a little puddle in front of the front one. Play wise though, they were fine.
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 07:13 PM
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
