Results 1 to 15 of 21
Thread: 1JZ smoky
    Default 1JZ smoky
    Need a bit of help with this one guys. My 1jz started blowing smoke recently. Blue smoke, oily smell. Started out as an intermittent problem, happening at different engine loads and speeds each time I drove the car (first couple of times was 2 weeks between each occurance), now it only happens at idle, and when cruising the accelerator. This makes me think vacuum related.
    If I start the car and let it sit idling, after about 5 minutes it starts to smoke. There is no smoke at initial star-up. If I load up the engine (auto in gear and brake/accelerator on) or rev it it just blows more smoke. Once I start driving it's a different story. When I pull up it smokes like all buggery but I can load up the engine to about 1200-1300rpm and the smoke goes away. Normal acceleration gives no smoke, but easy deceleration gives smoke, with more smoke if I completely let off the gas. Hard acceleration (even at neutral) gives off more of a light grey/blue colour smoke, whereas idling is very blue.
    Cleaned out the PCV and Idle control valves with carby cleaner, no difference. Oil and filter change, same. Compression is around 180-185psi in all except cyl 2 which had 165. Car idles perfect. no oil in the water when I changed it. Pulled off intake pipes from turbos, minimal play in the turbo shafts (no in-out play, only up-down). Did notice though that the intake pipe to the front turbo was quite oily, coming from the breather tube hooked up to the rocker cover. No apparent blow-by coming from the oil filler either.
    Need some ideas guys... this ones stumped me
    1JZ 1989 MZ20 Soarer - 3 week conversion all by myself
    200 rwhp 1977 MX36 Cressida wagon - off the road and needs a new home
    1986 Tarago campervan conversion on the go.
    2011 Toyota Aurion
    Nov 2007
    Default Re: 1JZ smoky
    Hows your valve stem seals
    Well from what I can remember from past experience bad valve stem seals don't start as an intermittent problem and don't blow this much smoke straight away. Also they usually cause smoke on initial startup whereas I have no smoke at startup.
    2011 Toyota Aurion
    Turbo Oil Seals ?
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
    Quote Originally Posted by Dieseltrain
    Turbo Oil Seals ?
    Possibibly (sic)...... Any way to check that without pulling them apart?
    2011 Toyota Aurion
    *bump*
    Any help please guys I haven't got the cash to take it to the mechanics and it's my daily driver I live 30 kms from work
    Anyone else had the same problem and fixed it?
    2011 Toyota Aurion
    Junior Member 1st year Apprentice JZX083's Avatar
    Mar 2009
    how many k's has the motor done??? what grade oil you using???
    Keep Left unless Oversteering!!!
    92 Silver JZX83 Cressida Grande Auto (Daily)
    91 Blue JZX83 Cressida Grande Manual GT3040 (Drifta)
    Sounds like turbo oil seals. Had the same fault with my car when I owned it.
    244rwkw / 328hp @ 18psi
    Is there any way you can replace just the Oil seals on the Ceramic turbos ?
    Still going good
    JZZ20 Backyard Mechanic forey's Avatar
    TAS
    similar problem here, on start up theres no blue smoke, but on any load/throttle it comes out like a cloud, would this suggest turbo seal? its a gt35r on 1jz
    trying to get it sorted, cheers
    87' z20 Soarer - 1jz Gt35r -
    Also check your PCV valve is operational, if its blocked you will get smoke like a turdbro oil seal is gone.
    RA23 - Twincharged
    JZZ20 - Daily
    Thanks Kedderz !
    IM gonna replace mine when i do the rocker cover gaskets . IM hoping thats all mine is
    Still going good
    The new PCV from Toyota is a bit straighter and is meant to fix the blow by problem the old 1JZs had. Made a bit of a difference in mine. I don't know how much smoke it's blowing now, but there was now oil in the front turbo's inlet pipe this time and the dip stick doesn't lift as much as it used to.
    TAS
    sorted it out, was the inlet oil seal on the gt35. cost me $720 for a full rebuild/balance.. now to find the money. thought it would have been abit cheaper but no-one in tassie rebuilds them so it was sent somewhere in vic
    cheers guys
    Gangnam style Automotive Encyclopaedia beatle's Avatar
    Perth
    thats not too bad, its what i would of assumed rebuilding a ball bearing turbo would cost.
    i know bush bearing turbo's are alot cheaper/easier to rebuild
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 07:13 PM
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
