Results 16 to 17 of 17
Thread: 1UZ auto clearance issues - Big Rubber Donut
    Tallahassee, FL USofA
    Default Re: 1UZ auto clearance issues - Big Rubber Donut
    Quote Originally Posted by aussie260z
    Someone else told me I could undo the big nut in the middle of the gearbox output shaft and remove thus completely remove the 3-pronged unit from the back of the Auto and use a normal slip-yoke instead - anyone ever heard of this before?
    It might be possible with the much shorter length & probably differently designed splines, if the power isn't being increased and/or the diff doesn'n move much.
    Redo all the mount/s & welding so it'll fit? That may need lots of time but little cash depending on your situation.
    Mar 2008
    No :-), I won't be re-welding that transmission tunnel!
    I need that support in there anyways - I guess I could remove the mounting "ears" and ditch that style of gearbox crossmember and make a style similar to that of the original Soarer gearbox crossmember, ie - one that bolts upwards onto the mounts!
    But, yes, that would be a lot of work :-)!
    I just bought a B&M Shifter - I will just fabricate the bits and pieces I need to get the cable operated shifter to work and do away with the solid gearbox linkages :-)!
  1. 1UZ auto box options
    Last Post: 11-02-2007, 08:33 AM
  2. big trouble little Soarer town - Auto issues.
    By Johnzoku in forum Tech and Conversions
    Last Post: 20-11-2006, 08:01 AM
