Results 1 to 9 of 9
Thread: 4age distributor 4 wire vs 3 wire
    May 2009
    Default 4age distributor 4 wire vs 3 wire
    Hi all,
    Long time lurker first time poster.
    I bought an ae86 recently which was half way through an engine swap from 4ac to 4age small port.
    I'm still finishing the wiring but i'm pretty sure everything is correct (12v to coil, injectors etc with ignition on) however it still wont start.
    Today I have just discovered there are 4 wires going from the ECU to the distributor BUT the distributor only has 3 wires coming off it (I think it might be a bigport dizzy or something).
    Is there any way I can get the 3 wire dizzy to work or do I need to hunt down the 4 wire one?
    If I do need the 4 wire one any suggestions on the best place to get one would also be welcomed.
    Thanks!
    Forum Sponsor Conversion King
    Default Re: 4age distributor 4 wire vs 3 wire
    3 wire dizzy has a 24 tooth home and 4 tooth reference so it won't run a sequential injection setup.
    the 4 wire has a 24 tooth home and single tooth refence but it has 2 sensors on the reference so it reads every 360* and knows exactly where tdc No1 is.
    You would have to get the right dizzy to suit whatever ecu you have, just check partnumbers on toyodiy.com
    linden
    0402727834 Grease Monkey turbo ke20's Avatar
    yes you should be able to use the 4 wire dizzy
    Instead of using 2 sensor on the 4 tooth wheel, you will only use the one.
    If u open up the ecu and see what pins the shielded harness goes to it should be
    "ne" this wire goes to the 24 tooth wheel sensor.
    "g1" this goes to the 4 tooth sensor"
    "g-" is the sensor ground (both sensors share a ground)
    thats about it.
    just make sure you line up your engine to TDC and the one tooth lines up with the sensor.
    justin
    PROWIRE PERFORMANCE WIRING
    Specialising in:
    -Haltech
    -Full Rewires
    -Engine conversions
    -Custom Air Con. Installations
    -Drag, circuit & show car wiring
    Justin Moore
    0402 727 834
    http://www.facebook.com/profile.php?...88667244568569
    4 wire dizzy only runs 1 tooth at the top.
    3 wire runs 4 teeth and it only does batch fire as its not sure where No1 is.
    May 2009
    Thanks guys I'm still hunting down a 4 wire one
    well in that case just grind off 3 teeth so you only have one tooth for TDC
    Specialising in:
    -Haltech
    -Full Rewires
    -Engine conversions
    Justin Moore
    0402 727 834
    May 2009
    Quote Originally Posted by turbo ke20
    Would that actually work?
    nope, as it still wont give you a tdc No4 reference (or 180* out on the dizzy)
    If you added another sensor you could do it but for all the hard work you would be better off finding a stock 4 wire
    Feb 2007
    Timaru
    Correct,
    3 wire dist has a 24 pulse and a 4 pulse, so only 2 sensors, and an earth wire
    4 wire dist has a 24 pulse and a 1 pulse and another 1 pulse, so 3 sensors and and earth wire.
    and FYI
    smallport 16v $AGE, 4AGZE, 20V, later 3SGTE + more, all have the same signal outputs.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
  1. 4age 16v into ra60 celica
    By nev194 in forum Tech and Conversions
    Last Post: 26-06-2009, 04:33 PM
  2. 4AGE -> AE86 Conversion: Accessories question
    Last Post: 17-06-2008, 08:53 PM
  3. Bigport 4AGE wiring questions
    By Nebuchernezzer in forum Tech and Conversions
    Last Post: 29-08-2006, 06:36 PM
  4. URGENT!RA60 fusable crossover wire magiver quick fix?
    By andyroo in forum Tech and Conversions
    Last Post: 03-01-2006, 08:11 PM
  5. 20v 4AGE into AE92
    By dale_8888 in forum Tech and Conversions
    Last Post: 16-12-2005, 04:51 PM
