Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: 4age 16v into ra60 celica
    Jun 2009
    victoria
    Default 4age 16v into ra60 celica
    hey i was just lookin for some answers/advise about a 21r-c to 4age conversion in my ra60 celica
    just first thing is there any modifacation needed to engine mounts ?
    can i use a FWD 4age n just get RWD engine mounts ?
    would it be worth using the T-series gearbox or just get a T to W bellhousing?
    if FWD 4age is easily useable will wireing loom needed to be modified or changed to rwd loom?
    would it be worth using a 20v 4age and get RWD engine mounts for that?
    i no these questions may seem pretty stupid but just wanna make sure every thing will be all good for the conversion and any help will be appreciated
    thanks nev.
    Default Re: 4age 16v into ra60 celica
    Will need to make up engine mounts.
    FWD and RWD engine is same block, so RWD mounts will be fine (but wont bolt to RA60).
    T-Series is fine, bellhousing for a 4A - W is hard to get so i wouldnt bother.
    Different wiring loom is small port, big port and 20v, FWD/RWD doesnt matter.
    20v are expensive and harder to setup.
    I think you should know that RWD 4ages are expensive and converting a FWD motor is a far bit of work, ignition, water pump, intake manifold, exhaust, accessories, and more all needs to be changed to RWD vr.
    Jun 2009
    victoria
    aww kk wasnt sure about the engine mounts as the AA60 celica in japan came out with 4age engines so stick to a rwd 4age with gearbox and should be ok for a easier conversion
    oregon
    just a devils advocate POV................
    The R engines are substantially "torqueier" then almost any n/a 4AG will be. You may want to consider using a 4AGZE... if you have the need to go with a 4AG...
    OR.....
    you might look into one of the "newer" truck engines(substantial torque)... the 2RZ, or 3RZ
    POV over... you may go about your day
    Victoria, Mt Macedon
    I think that given the weight of the Celica and especially the available space in the engine bay, a 4A may not be the smartest engine swap. It won't set your world alight.
    Dare I say 22RE, possibly turboed, may be an option. Or 1G or 1JZ or an RZ.
    Though if you are deadset on a 4AGE, google rwd 4age conversions and you'll drown in info. Most should apply to you.
    Hen
    Brisbane
    You will be very, very disappinted with this result.
    Lots of stuffing around involved and the car will go prettymuch like it did before except that you'll have to rev it more.
    Nov 2007
    victoria
    Unfortunately Nev is on his red p's so no performance mode like turbo or supercharged are allowed.
    But from what i have heard from people that if you put another engine in the car (as long as it was available in the car from another country it is still legal)
    As it came with that engine standard?
    Maybe we should worry more about handling and save up for a decent engine to work on so once he is able to have turbo or supercharged he will have a car that already handles good and just needs to put a good engine in it?
    But i could be wrong still.
    Jul 2007
    yes, that is exactly what you should do. fix the car up and save up for a 1G
    Jun 2009
    victoria
    the reason for me wanting to use a 4age because there such a popular engine theres pretty much endless amounts of tuning parts for them from wat ive seen, its more just i want to keep the car light weight aswell, im not to keen on a 6 cyl because of the uneven weight probly wont be too good for the corners but if its an easier conversion might consider it, thanks for all the advise everyone, if anyone else has some advise feel free to say wat you think any advise is appreciated thanks
    RA60 is about 1200kg, right? Toyota were putting 4AFEs into AE11x Corollas at around that weight. On top of that, Toyota put the 4AGE into lots of their top spec runabouts like the AA60 Carinas, the AT14x Corona, etc. With some intelligent decisions in regards to gearing, I'd say that it wouldn't be that bad. It wouldn't be a powerhouse, but it would probably handle fairly well. I'd like to do a Corona with one if I could find an AA60/AT141 crossmember.
    Brisbane
    If you are very attached to your car, spend your money on suspension instead.
    That way when your restrictions are lifted, you have a good base into which you can put a good engine.
    Or, even better, start collecting bits for a 1GGTE conversion now. You have NO idea how much it will really cost, the sooner you start the sooner it will be done.
    Jun 2009
    victoria
    Biggus:
    yer not 100% sure on the weight but according to the rego its 1050kg, so the crossmember in a ra60 an aa60 are different?
    Shifty:
    yer well at the moment im just running kings springs with stock dampers but i wanna get a set of monroe GT gas dampers quoted roughly around $390 for all corners, and when funds allow possably at set of VOLK TE37's or WORK equip 03's
    Nov 2007
    victoria
    Quote Originally Posted by Biggus
    The Ra60 according to the rego sticker on my car is 1090
    New Zealand
    Quote Originally Posted by nev194
    Yes crossmembers are different between the different engine families in the A6* chassis, not worth importing the right one though when a bit of work with the welder will solve that problem. As the gearbox spacing seems to be the same on all the ones I've looked at, swing in the motor and box and bolt up the gearbox crossmember. From there your engine placement should be correct so just make mounts to suit.
    Personally, a 4A swap just simply won't be worth it. As you already have an RA60 I would go for the 18RG as it was also a factory option in the RA63 and gives you the torque advantage you will need over the 4A. Will probably work out cheaper too.
    Callum
    Coronas/Celicas etc which had the A-series engine (be it 4AFE, 4AGE or 7AFE) were generally base-model ones, not top-spec, and were the slugs of the bunch
    And the 4AGEs that were going into AE101 and AE111s were the 120kw-ish 20v versions not 86 or 100kw 16v versions, again more difference (and they were about 1000-1100kg, not 1200kg)
  1. Replies: 308
    Last Post: 09-06-2009, 01:22 PM
  2. RA60 or RA40 struts into a TA22 Celica? Increasing track?
    By -NiCkeL- in forum Tech and Conversions
    Last Post: 14-08-2006, 10:12 AM
