Results 16 to 30 of 38
Thread: My UZ83's Fuel Ecconomy
    Default Re: My UZ83's Fuel Ecconomy
    yeah maybe i shouldve qualified the economy of the UZS131 by saying it weighs in at 1850kg WITHOUT a driver.
    ...... butt scratcher?!
    The Celsior would roughly be the same weight, and city driving easily nets 14L/100km.
    Act
    yeah I get 13ish litre per 100km around town, but it worse now that I work closer to home
    12l/100 on the open road.
    63 litres gets me around the 480-500km mark
    550ish on a trip
    Quote Originally Posted by onboost View Post
    Hey mate,
    Must be something wrong with it. I used to get 420 on e10 and 450 on pulp. It used to change gears at 6000.
    Yep, Spark Plugs were seriously worn.
    But still sucking fuel.
    Junior Member Carport Converter ecko's Avatar
    May 2007
    tasmania
    Quote Originally Posted by Aust162 View Post
    Doesnt sound right to me. my mates uzz30 soarer gets 500kms+ off a tank consistently..
    dont soarers have a epic huge fuel tank?
    I'm getting around 350 to a tank or premium.
    Quote Originally Posted by ecko View Post
    Im referring to the original post ^ . And im pretty sure they do have massive tanks, like 70-75litres? (never owned a soarer)
    Damm this thread is O.G!
    Ok so to update this.....Still having a problem..
    I test the water temp sensor and its within toyota spec however the outside casing(where the plug clips to) is a bit loose. Will replace along with a full service and will update
    Seriously Cuzzo replace the sensor, JoJo mentioned the same fuel economy problem in the Celsior dedicated thread. Replaced the Temp sensor, and all was returned to normal. I had the same problem, and the sensor replacement fixed it, used 40 litres to get from Canberra to Dubbo after.
    MS51Crown Coupe,
    Sep 2008
    Did you find the cause of the weird limiter thing?
    The GOD HAND AW11 - sold
    Junior Member Domestic Engineer NeoNasty's Avatar
    yyaarrrr. We haz 80 Liters to da tank. So not huge.
    HZJ75, RS41, JZZ30
    Just to update guys.
    Found a larger restriction with the small air filter that was on it. I put a large (pod) airfilter on it and it revs hard now, all the way to redline and changes good.
    Economy is still a bit average. I replaced the water temp sensor, full service including auto and diff. Seems to be going alot better now. Dont know economy cause the speedo stopped working...
    Not one thing its another!
    http://cgi.ebay.com.au/Toyota-JZX81-...item588923134f
    Then you'll have a sweet light saying TURBO too, so you can dream of really having a 1J
    Aug 2008
    Stop doing helis.
    visit us at www.zengarage.com.au OR pop into our store at 7/99 Moore Street, Leichhardt.
    Jul 2007
    ^ that would be like dividing by zero for cuzzo
    Quote Originally Posted by Bananaman View Post
    Best part is that if you do get that, your fuel gauge will read full all the time
  1. fuel pump losing the plot ??
    Last Post: 17-06-2008, 07:14 PM
  2. Differences in 18r fuel pumps?
    By sam_ in forum Tech and Conversions
    Last Post: 09-04-2007, 04:00 PM
  3. electric fuel pump for weber - which one?
    By slapper in forum Tech and Conversions
    Last Post: 01-03-2007, 08:09 AM
  4. VL fuel pump making strange noises and fuel lines rattling
    By phrostbyte in forum Tech and Conversions
    Last Post: 12-02-2006, 12:04 AM
