Results 1 to 8 of 8
Thread: 3T-GTE spark leads
    Apr 2009
    south australia
    Default 3T-GTE spark leads
    Just wondering what brands out there make leads for the 3T-GTE as mine and onthe way out. Topgun ect? If anyone has part numbers that will be great help thanks.
    I like Cheese Backyard Mechanic Jackel's Avatar
    W.A.
    Default Re: 3T-GTE spark leads
    topgun do ive seen the part number but cant remember it.
    Junior Member Grease Monkey Beserker99's Avatar
    Just checked the catalogue I have on my computer, part number TG4533, for "3T-GEU DOHC Yammaha Head (Identified by dual plugs and distributor - 10 leads to the set)".
    Hope that helps.
    New Zealand
    i'm guessing price will hurt. Other option which I'm sure the details of where around here somewhere involves swapping the boots over to a set of 302 Ford V8 leads (better check on that) and it worked out way cheaper. Just needed an extra coil lead.
    Callum
    Edit - and right below in related threads is this -
    http://www.toymods.net/forums/showthread.php?t=29944
    On mine I have removed the boots from the original lead and placed the boot onto topgun leads, fairly painless procedure and still seals very well. Reduces the cost of leads
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    Apr 2009
    south australia
    thanks for your help guys
    just another questions, if i relocate the coils closer to eachother, will that be dangerous in any way as i whant to make a custom airbox
    should have no issues at all
    what you have to consider is where you put them and if there is height clearance and if they are closer, then you would want shorter leads
  1. Wasted Sparks VS Sequential Spark
    Last Post: 07-01-2018, 11:19 PM
  2. cheap replacment 3tgt spark leads
    By Slonlo in forum Tech and Conversions
    Last Post: 10-11-2007, 06:20 AM
  3. 3T GTE - Wasted spark??
    Last Post: 11-04-2007, 08:34 PM
