Results 1 to 4 of 4
Thread: 4age head tension
    senior backyard mechanic Grease Monkey legend's Avatar
    Default 4age head tension
    looking for the specs to tension a head on a 4age bigport
    need the specs for the cam caps also
    thanks
    S.A
    Default Re: 4age head tension
    head torque 22ft lb / 29 Nm torque head bolts evenly
    then 90 deg on all bolts
    then another 90 deg
    This is the factory torque for new bolts.
    If you are re using the old bolts it should say what torque to do them to on the carboard that comes with the new head gasket.
    They are a stretch bolt. but i no of people including myself who have re used them in the past with no prob
    ARP studs 60 ft lb
    cam caps are 9 ft lb / 13 nm I do mine to 15 nm cos i use
    hks valve springs.
    south australia
    30 pound has it sussed!
    If you want more indepth overview then the 4age book on teh old forums is your friend
    http://toymods.org.au/Repository/Tec...derhead_19.jpg
    http://toymods.org.au/Repository/Tec...derhead_20.jpg
    thanks south oz guys awesome
  1. Replacing head bolts with studs.
    By PHOBIA in forum Tech and Conversions
    Last Post: 17-09-2011, 11:36 AM
  2. 4AGE 100kw smallport turbo rebuild
    By BoostBoy in forum Tech and Conversions
    Last Post: 07-05-2007, 10:24 PM
  3. will 4age head fit on a 4afe bottem end?
    By born_rolla in forum Tech and Conversions
    Last Post: 02-05-2006, 11:21 PM
  4. 4age head gasket thickness
    Last Post: 06-03-2006, 04:42 PM
