Results 1 to 14 of 14
Thread: 7MGTE Dies
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Default 7MGTE Dies
    I've thrown a 7MGTE into my MX83 but before I pulled it out of the donor car, it took a few turns for it to run properly. You would start it, idle for a few seconds then die. After a few shots, it would idle and run fine.
    Now that the motor is in the Cressida, it has the same problem but it always stalls after a few seconds. The fuel pump is still buzzing away after it dies so its not that.
    Could it be the injector ballast?
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    Nov 2007
    Default Re: 7MGTE Dies
    Did it throw any codes?
    South Austrlia
    It doesn't run long enough for me to check the codes. Can you check em while the ignition is on?
    Nov 2007
    Check for codes any way.
    codes will generate even if its not running, its probably not getting a rpm signal or something and telling the computer to cut ignition or such like.
    RA23 - Twincharged
    JZZ20 - Daily
    South Austrlia
    I'll check if its throwing any codes tomorrow morning.
    I found out that it dies whilst the spark is going.
    South Austrlia
    Code 31
    Air Flow Meter Signal
    Diagnosis
    * (7M-GTE) Open or short circuit in air flow meter signal.
    Trouble Area
    * Air flow meter circuit
    * Air flow meter
    * ECU
    If I rev it a bit, it'll stay running a few seconds more but it'll die anyway.
    I've changed the AFM once before. After I did that it ran fine and it was started for nearly 3 months. Now this
    Do I try another AFM?
    yes try another afm or at least the electronics in your afm body, and make sure yours is currently connected.
    South Austrlia
    Yeah its conected. What I don't understand is why it worked before and now it doesn't.
    South Austrlia
    I tried a 1UZ AFM and its still the same. I've checked the wiring and the earths that relate to the AFM.
    WTF?
    are you trying new electronics that are known to work with the different afm or just the body with your electronics in it?
    at idle if i unplug my afm the car still runs but drops revs and it cant be reved fast or driven.
    what happens if you start your car with the afm unplugged, it stills dies?
    South Austrlia
    I've change the electronics once. I tried the 1UZ electronics this afternoon.
    If I unplug the AFM it will sort of start but it won't run like it would with it plugged in.
    Nov 2007
    d-master it might help if you know of some one with a simillar ecu as yours to swap and check to see if the ecu is faulty.
    and it still dies regardless if the afm is plugged in or unplugged?
    id be looking elsewhere.....
  1. 7mgte power results (6 / 5mgte's welcome)
    By mux in forum Tech and Conversions
    Last Post: 16-08-2007, 05:41 PM
