Results 1 to 7 of 7
Thread: 4age 20v rwd sump?
    20v Silvetop / A40 3spd 1st year Apprentice
    Apr 2008
    Default 4age 20v rwd sump?
    Are there any rwd 4a motors out there from factory that would bolt up to a 20v with the sump bowl at the rear of the engine and the pickup pipe picking up from the standard 20v front inlet to reach to the rear of the sump?
    looking at options before I chop up my 20v sump
    Junior Member Backyard Mechanic KARNAGE's Avatar
    Default Re: 4age 20v rwd sump?
    the answer is no as the 4age 16 valve sumps are slightly different to the 20valve supms as they have the cut in on the side.
    Victoria, Mt Macedon
    In addition to that, all 4As I have seen, both FWD and RWD, have been front sump.
    Conceivably there may be a rear sump in something funny like an early Tercel, but I would be surprised.
    Hen
    Apr 2008
    Hey guys,
    Thankyou for the replies. It seems in my reseach that you are correct in saying that the regular 16v sumps have no cut in like the 20v. my 20v is going into a suzuki sierra and considering a lot of load is put on the motor when driving up steep obstacles I felt a rear sump collector would make life easier on the motor and it also works into my front diff placement which happens to compress up towards the forward part of the block.
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Unless you have a huge lift kit on the Zook then a rear bowl sump will hit the front diff. The front bowl sump clears better and I have never ever had any oil starvation problems with steep inclines in mine.
    plus they have the baffling in them anyways so even on a steep incline there will still be oil availble to the oil pickup
    Apr 2008
    Quote Originally Posted by Bazooka
    Hey Bazooka, my diff is around 1.5 inches forward with a RUF running 34" swampers 2" springs, 2" shackles, 2" body lift and all the measurements i've done and test fits with the sump on the normal way have seen my diff compress into the front section of the block. wanting to keep the engine as low as possible flipping it gives me that little bit extra room. My engine is a fair way forward as well as I haven't touched the dizzy at the back of the head either. I have about an inch of clearance from the firewall to dizzy on my last measurements. Body is off at the moment and the sump has already been chopped so I'm hoping that when it all goes back together i've done my measurements right. Do you have any pics of your engine in your zook? is yours a 20 or 16v?
    Dan
  1. Cressida MX73 Conversions Guide Book
    By twentyEight in forum Engine & Driveline Conversions
    Last Post: 24-02-2007, 11:07 AM
  2. 4AGE 86KW TVIS V 100KW 4AGE + Shocks
    By GeeEss in forum Tech and Conversions
    Last Post: 17-01-2007, 09:51 PM
  3. 1g-gte front winged sump into TA23 Sway Bar issues!
    By hemi twofifteen turbo in forum Tech and Conversions
    Last Post: 21-09-2006, 11:08 PM
