Results 1 to 6 of 6
Thread: TA/RA handbrake grip removal
    Texas Hold'em Junky Backyard Mechanic fade-e's Avatar
    Default TA/RA handbrake grip removal
    Hey all,
    i want to remove the handbrake grip for my '22 so i can get the handbrake powdercoated. Can anyone tell me the easiest way to do this without breaking it (the hand grip)?
    I know it is glued on, but what is the easiest way to remove it?
    NOTE: easiest also includes not damaging
    Default Re: TA/RA handbrake grip removal
    Posted in wrong section but how about heating it in hot water and the wrapping the plastic in cloth and the trying to pull it off in a vise?
    kinda like a slide hammer where you tighten the jaws of the vise so that the tube slips through but the plastic handle wont so the shock of the plastic bit hitting the jaws breaks the glue bond
    ooops my bad all... please move if you dont mind
    will try that stidham... thanks
    burn it off?
    If it is glued on, you could inject (using a syringe) some thinners or alcohol to try to break the bond and slide it off?
    Simon
    Beige.... The new Black!!!
    well i did the hot water option and it worked a treat
    the grips came off with no issues...
    cheers all
  1. Front handbrake cable
    By parrot in forum Tech and Conversions
    Last Post: 25-02-2008, 09:49 PM
  2. AE86 Handbrake, Hilux Diff
    By 70XIN in forum Tech and Conversions
    Last Post: 31-08-2007, 09:37 AM
  3. RA## Celica handbrake fix.
    By willwal98 in forum Tech and Conversions
    Last Post: 05-12-2006, 08:38 PM
  4. hydraulic handbrakes......good read for those into motorsport! ;)
    Last Post: 09-08-2006, 10:55 PM
