Results 1 to 15 of 19
Thread: R154 will not select Reverse
    Junior Member 1st year Apprentice JZX083's Avatar
    Mar 2009
    Default R154 will not select Reverse
    Hey guys,
    I just recently finished a jzx90 half cut conversion into another Cressida. Took it for a drive and it drives great only problem is the R154 will not select reverse. The box is actually out of a JZA70. I have tried a different stick to see if that makes a difference with no luck. Does anyone have any ideas what this could be before i go and take the box out???? Could it be something simple that i'm missing??? It doesn't even feel like there is a reverse gear there. There is no clunking or grinding or anything it just wont select it. It seems to select 5th and drive fine in 5th. I know it uses the same selecter lever as reverse. Thanks guys,
    Cheers.
    Keep Left unless Oversteering!!!
    92 Silver JZX83 Cressida Grande Auto (Daily)
    91 Blue JZX83 Cressida Grande Manual GT3040 (Drifta)
    Default Re: R154 will not select Reverse
    Tried pushing down or pulling up on the shifter while grabbing reverse?
    I am the sun
    Mar 2009
    Yeah mate tried all the usual tricks, push down, pull up, pumping the clutch. tried putting it in 1st or 5th. tried rolling the car while trying to select it. also have tried holding it on reverse and slowly lifting the clutch up. it doesnt sound like reverse is even there no grinding or anything.
    Can you get reverse with the engine off?
    Are you sure the clutch is disengaging fully?
    There is a mechanical interlock which prevents shifting into reverse from 5th gear, maybe jammed?
    Mar 2009
    hey mate,
    nah i cant get it with the motor off either. I assume the clutch is working properly as every other gear is smooth and its not as if the clutch is working on the floor.
    As for the mechanical interlock im unsure about??? Thats inside the box or the extension housing???
    Apr 2007
    It sounds as if the gearstick actually moves over & down to the reverse position ( but no reverse ) if this is the case & it definately is going all the way over & down, it doesn't sound good .. Could be a smashed reverse idler etc ...
    Drop the gearbox oil out of it into a clean container & look for some chunky pieces ..
    Mar 2009
    Yeah mate when compared to my other manual it feels like the stick is moving the same amount. The gearbox oil is only 5 days old and as the car has only been round the block im not sure it would of picked anything up as it was probably a previous problem. But i think ill try dropping the oil anyways just incase it has managed to pick up any signs of chunky bits!!!!!
    Tallahassee, FL USofA
    Probably a broken fork if the stick moves fully/ positively into position, yet there is no 'reverse'.
    I hope it doesn't slide & try to get into reverse when driving & in any other gear.
    Good luck.
    Mar 2009
    Yeah thanks mate,
    But would i be right in saying if it was a broken fork i would not be able to pull it out of 5th??? Because 5th and reverse are on the same selector fork!!!
    Mar 2009
    Hey,
    Does anybody know exactly what the reverse restrict pin does on the side of the box???
    Does it apply pressure against the shift into reverse or does it stop it from jumping out of reverse once its in, or does it just simply centre the gear so you cant overtravel it???
    Apr 2007
    I pressume you are talking about the detent ball / pin. as you have already said its just a locater on the selector shaft, stops it from falling out of gear, but certainly wont stop it from jumping out ..
    Mar 2009
    The little reverse restrict pin in that drawing is what i was talking about. not sure if thats what you were thinking of???
    Tasmania
    So are you sure the gear is even on the shaft? It all sounds very strange and maybe reverse was renoved for repair or replacement and was never put back in prior to sale? I know bugger all about gearboxes and don't even know if what I said above is actually possible, but it seems certian you will have to pull the box out.
    Mar 2009
    Yeah I'm thinking i might drive the car round to the place i bought the cut and box off of and ask him what he's going to do about the box??
    What do you guys think he should do about the box not selecting reverse i only bought it about 3 months ago!!!
    Tasmania
    Well it can't hurt to take it around there and show him the issue and then politely ask if he knows what's wrong or how to fix it or if it was ina driving car previously. I hate taking shit back though because they always say it was fine when it left them! It would be funny to hear them say that and then find out there is no 5th gear in it all.
  1. r154 shifting experiences
    Last Post: 24-11-2009, 09:47 PM
  2. R154? Good or no good?
    By TTV8RA23 in forum Tech and Conversions
    Last Post: 12-02-2008, 09:18 AM
  3. R154 gearboxes
    By AEhachiroku in forum Tech and Conversions
    Last Post: 06-09-2007, 01:38 AM
  4. R154 Rebuild Questions
    By delazy in forum Tech and Conversions
    Last Post: 22-08-2007, 06:14 PM
  5. A340E lost reverse :(
    By whatthe? in forum Tech and Conversions
    Last Post: 10-03-2006, 02:50 PM
