Results 16 to 30 of 32
Thread: Hilux Diff Centre - JZA70 Torsen Installation
    Default Re: Hilux Diff Centre - JZA70 Torsen Installation
    so an ln56 diff will be an easier fit? cant remember what year model it was
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Act
    I had similar issue with my RN25 housing and true trak, Not sure how it went together but my diff guy said he threw away my RN25 centre housing and used a later model one when fitting UZS131 3.9's and the true trak
    Mar 2008
    westmere
    are the shaft splines on the jza70 lsd the same as the hilux 5 stud 2wd axles ?
    yes..................
    Jealousy is a curse
    May 2007
    i have a mechanical lsd for sale
    May 2010
    Just reading the information on removing metal from the pinion to allow for clearence so I thought I'd pass this on.
    When fitting ARB airlockers to Hilux diff's in the instruction manual it refers to the need for grinding metal off the top of the pinion to allow clearence of the air locker centre. I have done this in a number of cars, some being good friends of mine and have never seen a pinion brake because of it so I wouldn't be at all concerned about removing 1mm or even 2-3 for that matter as it seems to make next to no difference to the strength of the pinion.
    Most competition Hilux's are running reasonable HP with 1uz motors and ARB airlockers and pinion failure is not something that ever seems to be an issue.
    Aaron
    vic
    4 year thread revive .
    Thats strange i have fitted many toyota ARB,s and no pinion mods at all , what model ARB lockers have you fitted.
    Dave
    May 2010
    The last 2 I did where on LN106 Hilux front diffs - 4.3 gears and both required pinions to be ground smaller, and the one before that was a Hilux centre but unsure of model as it was done to a diff a mate bought.
    The ARB manual for installing air lockers states that it may need to be done. Part number or locker from memory is RD132.
    This is the ARB site that states about pinion grinding;
    http://www.arb.com.au/resources/pdf/airLockers/5-06.pdf
    Obviously its must not be all of them if you have never had to do it....
    Aaron
    Jan 2008
    queensland
    Quote Originally Posted by ooh808 View Post
    How much for the mechanical LSD?
    May 2007
    sorry man, its a detroit, i dug it out and stripped it, way to long ago i sold the mechanical lsd, woops
    i put a ma70 clutch pack lsd and gearset in my yn57 2wd, i had to have the bearing carries turned down to fit hilux bearings as the internal bore was bigger on hilux....as far as fitting it was fine, tight to get in initially but yeah worked perfect...
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
    vic
    Ah RD132 , the new ones , ive only fitted a few and all to OE geared diffs.
    Another reason the older RD23 is better but still a reason not to use them .
    Check one of the side gears , it has a female circlip groove machined in it and on some applications the axel only engages on 20 mm of axel spline . after 100000klm = chopped out splines.
    Dave
    Jun 2009
    Tokoroa
    HI, Im looking at putting a jzx90 torsen carrier into a hilux head,Ive yet to buy the torsen....I do have three different heads that all have different size side bearings is there a special bearing that i will need to get? are the jzx90 /100 torsens still as good as the jza70s ? any help would be great
    PS , this is for dirt track racing.
    You will need a spacer and the appropriate bearings.
    Jealousy is a curse
    May 2007
    i have laser cut/cnc 1s, $30
  1. G series diff centre pictures anyone?
    Last Post: 16-01-2008, 07:29 AM
  2. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  3. changing the gear ratio's in hilux diff.
