Results 1 to 6 of 6
Thread: 2t radiator upgrade
    Low rep 1st year Apprentice
    Jan 2009
    Default 2t radiator upgrade
    wats the largest radiator i can fit onto my ta22 2t engine.
    Too old to be a Grease Monkey
    Aug 2008
    Default Re: 2t radiator upgrade
    I have it on good authority that Nathan at Just alloy radiators can make you a triple core TA22 radiator.... Send him a PM ,. RiceburnaGTV
    other than that I have heard rumours of an excel radiator which fits the TA22 framework but havent ever seen one? better to get one from Nathan.
    Banned Grease Monkey toyboyracer's Avatar
    Thumbs up Re: 2t radiator upgrade
    Why?
    With a clean system and a good stock rad and thermostat = No probs
    Thought the same thing 2 1/2 years ago, our 2nd project has been flogged everywhere & still good.
    Arrrrghhh....
    NO NO NO - Plastic crap that goes pfffttt @ the drop of a hat !
    Most times the original actually is best !
    someone say 2t-ze? Automotive Encyclopaedia gerald1's Avatar
    South Australia - ADL
    its ture that RiceburnaGTV can make you an incredible radiator but the stock one does the job fine. I had a completely fckd stock radiator for ages - all the fins were rusted and the channel things were blocked etc. etc.. and it still kept my car cool for 2 years. I now run a ke30 radiator in there and while its not as big it fits with minimal modifications - i got it for a complete bargain at a wreckers so i used that instead of getting my stock one record. The early ta22's - 71,72 - had even smaller radiators than the 73-75 models. If you do have problems maybe just get it re-cored.
    ta22 Green with cream vinyl roof, 2t/3t hybrid with a few go fast bits on + 5 speed.
    May 2006
    tas
    i put a single core nissan 180sx rad in my rolla, its cooling a 4ac. fairly big single core aluminium. cools kinda too well, so much so that with no fan it takes quite a while for the thermostat to open fully on cold mornings. never over heats in traffic which is about the only time i turn the manually switched thermo fan on.
    they are cheap as, same as s13 etc, only just clears my bonnet tho as they are a bit taller.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    Not known unless ur blown Backyard Mechanic
    May 2007
    Use an RA23 radiator its wider, you just hav to make two metal tags, to bolt one of the sides up. The other side you just bolt in the standard holes.
  2. comparing 2T and 2T-G standard pistons
    By w810sc in forum Tech and Conversions
    Last Post: 02-01-2007, 05:28 PM
  3. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
  4. 2T Head and 3T Block, standard items - any problems?
    By -NiCkeL- in forum Tech and Conversions
    Last Post: 09-11-2006, 01:29 PM
