Results 16 to 30 of 35
Thread: AE82 4AGE starter motor
    Default Re: AE82 4AGE starter motor
    unless of course you have extractors, which is a reason that these starter motors fail faster..
    also do you have a relay already hooked up to the starter motor? that usually helps but is really a temporary solution
    Traditionalist Domestic Engineer parrot's Avatar
    Quote Originally Posted by Shifty
    Actually out of interest I have already priced one from Repco, at $476.00 they can stick it
    Holy f#$%^n batshit!
    That's a bit extreme. In rear drive format you can get this starter out without removing the exhaust manifold. But I wouldn't pay that much for the privilege.
    So looks like it's off to the auto elec for a change over. Make sure you keep the heat shield as they don't all have one. Or down to the pickies which is what i would be doing, and where I found my repco item. You will probably find one there that has a reco sticker on it. Any car with a 4AC or 16 valve 4AG will fit.
    Cam mountain I feel different from the ordinary
    remove gearbox to change starter? you guys are on crack
    They were referring to if he was to swap the starter to the other side, in which case he would need to remove the backing plate, and to do this = gearbox off.
    FYI - Extractors still need to be unbolted and moved to get the starter out.
    Brisbane
    Quote Originally Posted by parrot
    Can ayone confirm? That's what I was kinda asking at the start, before we went on the tangent.
    Do I have to get one from a 4AGE or can it be a 4AC? Can it be a 4AFC or anything else? Nothing's ever fricken easy
    I got a pice on a rebuild, $180-$330 depending on what it needs.
    Brisbane
    Oh and yes it has extractors, I can't forsee a problem removing it as there looks like plenty of clearance.
    Sep 2008
    I have 2 FWD 4age starter motors, if u want one PM me we can come to a price incl shipping!
    The GOD HAND AW11 - sold
    Brisbane
    I've sent you a PM.
    Tallahassee, FL USofA
    sometimes I only get a 'click' when going to start the car. Rocking the car back & forth a few times allows me to start the car.
    What kind & where of 'click', a little noise from some relay under the dash, or a loud 'thunk' from the starter solenoid? Clutch switch?
    Jumped the stater by putting 12V to the solenoid's small terminal?
    The solenoid may not operate from receiving too little current or from going bad & needing more current then the system can supply, and cleaning connections or adding a relay can cure this.
    If the solenoid moves the starter drive but doesn't make enough contact to feed current to the stater motor, then cleaning/replacing its contacts should fix it.
    Moving the car will never do anything for any starters electrical problem, only a mechanical problem of the starter drive jammed with the ring gear.
    An AE92 will have a different plug. Starter looks aesthetically different but should bolt on.
    Brisbane
    Quote Originally Posted by LeeRoy
    Ahh fuck really?
    I pulled mine out and then when I went to put the new one it the plug was wrong, and it looked completely different, so I figured it was the wrong one and put the old one back in.
    Does this mean the one I've got is actually ok, and I've gotta pull the carnt apart again to fit it?
    Aside from looking externally different, which isn't an issue, the bolt spacing seems OK. My main concern is that the existing starter has a 'snout' on it over the engagement gear, and the new one doesn't. Can anyone comment on this?
    Sep 2008
    hey shifty, when im at my dads workshop next, ill get some pics of the starter motor i have left over and we can compare then and work something out if they guys cant figure out the plug thing...
    it is strange though as both of my starters where pulled off AE82s
    Brisbane
    A mate of mine owned this car for 10½ years and didn't ever replace/reco the starter motor... although it does have a reco sticker on it so there's a chance it was replaced with a different one?
    I just had a look on my phone, and I didn't think to take a pic of the starters beside each other! I'll see what I can google................... ok I googled "4AGE starter motor" and it came up with this pic, which looks prettymuch like the starter that's on the car presently (note the snout on the end).
    Sep 2008
    alright well ill have a look and see....
    Brisbane
    Has anyone got a picture of the "gear reduction starter" everyone seems to want? Maybe I ended up with one of those (would be unlike me to end up with something good by chance... normally I pay extra for something shit).
    Not what I found.
    Just takes some wiggling and maneouvering and you can eventually get the starter out and in without unbolting extractors (on ae82 twincam) (you'd wanna make sure you dissconnect the battery first though )
  1. 4age Starter Motor Problems?
    By dogeatdog01 in forum Tech and Conversions
    Last Post: 30-07-2008, 03:50 PM
  2. 4AGE .... what generation motor do i have
    By _FNQ_rolla_ in forum Tech and Conversions
    Last Post: 23-03-2008, 10:24 AM
  3. 4afe/ae101 Starter motor
    By Kedderz in forum Tech and Conversions
    Last Post: 15-03-2007, 07:47 PM
