Joshua, the manual gearbox behind a 1G-GTE is normally a W58.
W55,W57 and W58 all share the same bellhousing to gearbox bolt pattern regardless of bellhousing. The RA2x W5box is not similar to either of these other boxes.
The bellhousing you require to mount a W58 to a 1G-GTE is unique to the 1G-GTE, however the 3T-GT bellhousing will suffice, as the engine to bellhousing bolt pattern is identical to the 1G-GTE. The glitch is that the clutch slave cylinder on the 3T-GT bellhousing will be on the exhaust side when fitted to a 1G-GTE.
The gearbox crossmember simply requires an extension bar on each side, the centre hole will also need to be enlarged, for the adjustable stop to drop through.
cheers Chuck.
ps, check the members ride threads and conversion threads, I am sure you will find the other info there.
