Results 1 to 15 of 15
Thread: auto trans cooler lines
    Default auto trans cooler lines
    So I've got the auto trans lines on the a340e that came with the 1uz.
    They are solid, and a solid pain in the arse.
    What have people done to replace auto trans lines with something more useable and flexible?
    Facebook | LinkedIn
    Montrose
    Default Re: auto trans cooler lines
    Replace them with hose.
    rubber? braided, etc?
    how does the hose attach to the box? can I just hose clamp it onto a cut off part of the metal pipe?
    Facebook | LinkedIn
    Montrose
    Cut the steel pipe off someplace convenient, use a double flare tool to put a small lip on the end of the pipe, and use a hoseclamp. Auto trans cooler hose doesn't cost that much at any car parts place/hose and fittings place.
    Facebook | LinkedIn
    sorry for the double post, toymods fucked up as usual
    Facebook | LinkedIn
    i was lent this special tool to cut the solid lines so i could fit a high pressure hose over it with a hose clamp.. and yea this has worked, no leaks and no sign it will leak..has been going strong for 10,000 kms and the car just sold, straight into a 16 hour journey..
    braided lines are an options but very expensive and not worth it for just a normal daily imo.. i paid 20 bucks for that length of hose, some clamps and 10 minutes with the cutting tool
    edit : oh i had to use the tool because when i cut it initially i kinked the line.. the tool is small and sort of cuts around the pipe if you know what i mean..
    strad: just use rubber hose with worm-drive clamps that don't cut the hose ... and make sure you get the right ID of the hose. Toyota power-steering hard lines seem to be larger than local items.
    Splendid, thanks Chuck.
    seems like that's the go.
    Facebook | LinkedIn
    yea we just use fuel hose (!)
    last time i did a new cooler though i bought proper TRANSMISSION hose which wasnt that exy.
    Transmission hose it is...
    Facebook | LinkedIn
    Quote Originally Posted by Vios-GT_07
    What, you mean like a Pipe Cutter.
    Who woulda thunk it.
    Pipe cutter, 3/8 trans hose ftw.
    sorry i had a mental blank.. it is a pipe cutter..
    Captain Red Grease Monkey SuperDave's Avatar
    Sep 2007
    I know you have already gone for the rubber hose, but to reinforce why you don't need to pay through the nose for braided is why do you need a hose with a burst pressure of 1500-3000PSI. I'd rather a hose go then a gearbox/cooler/etc.
    My Sled, My Videos
    The tow goes above the tow hook
    I got rid of my hardline metal trans lines a few years ago and replaced with standard transmission hose, never had a problem. Just keep it well clear of your exhaust components.
    244rwkw / 328hp @ 18psi
  1. Using air con condenser as auto trans cooler
    Last Post: 28-09-2017, 03:40 PM
  2. 4AGE auto trans flexplate.......
    By oldeskewltoy in forum Tech and Conversions
    Last Post: 04-08-2007, 01:43 PM
