Those things are low value resistors. The HT is the heater circuit for the o2 sensor.
It is in series with the heater so that if the heater goes short ciruit the ECU doesn't blow up.
7M ECUs use them in series with the injectors also.
O2 Heaters are about 20 watts when cold and about 5 Watts when hot.
Check your good one again that said one OHM then short your multimeter leads together and see what that says. The difference should be approx the resitor value you need.
Good luck
That means the resistor in my good ECU isn't really resisting, more sitting there allowing current through.
