Results 1 to 5 of 5
Thread: 2jz blowing blue smoke
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Default 2jz blowing blue smoke
    My 2jz has had the usual jz valve stem seal problem since i got it. It would blow a small amount of blue/oil smoke on cold start up. But now it seems to puff very small amounts through out the rev rage, especially when you back off the throttle. I'm concered it could be the rings. Can't be the turbo cos it's only done about 1000km's.
    Anyone here experianced similar amounts of smoke from a jz motor? Whats the best way to test if the rings are buggered?
    1994 GZX90 Mark II 1GZ-FE V12
    Nov 2007
    Default Re: 2jz blowing blue smoke
    How about a wet and dry compression test, do a dry test first, then if you add oil and the compression raises, that would give you a clue if it's the rings or not.
    Forum Sponsor Conversion King
    stem seals gone hard? get them changed and it should be all good.
    Back off the throttle = high vac condition --> likely to be VSS....
    My thoughts. You know they are average anyway so replace them and see if problem persists
    Wilbo's JZA80
    Wilbo's JZZ12
    Cheers for the help guys. I'll be replacing the stem seals soon, along with cams and valve springs.
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 05:27 PM
  2. 2JZ Water Pump onto 1JZ
  3. GT4 Blowing smoke?
    By Sledge in forum Tech and Conversions
    Last Post: 04-05-2008, 02:06 PM
  4. 4AGE - smoke machine
    By Grega in forum Tech and Conversions
    Last Post: 18-04-2008, 09:29 PM
  5. Blue smoke after boost....turbo seals?
    By tooch in forum Tech and Conversions
    Last Post: 13-02-2006, 11:24 PM
