Results 61 to 67 of 67
Thread: GT3076R 4agte help guys
  1. #61
    South QLD
    Default Re: GT3076R 4agte help guys
    This web site shows a divided .78 exhousing
    http://www.atpturbo.com/Merchant2/me...egory_Code=BCS
  2. #62
    GameOn Backyard Mechanic Poggy's Avatar
    Quote Originally Posted by Cameron_Datto
    That wont fit my gt30, my gt30 is the smallest of them, that housing only suits the larger wheels
  3. #63
    Forum Sponsor Conversion King
    What size is your rear wheel? is it the 60mm GT30 wheel or the modified version which is 55mm or there abouts? if its the smaller wheel you could probly run a T28 size housing which even though the A/R is a similar number it will cause it to spool a fair bit quicker.
    linden
  4. #64
    S.A
    what was the go with the tial gate?
  5. #65
    Quote Originally Posted by 30psi 4agte
    what do you mean
  6. #66
    Okay what a absolute screw around. Apparently the only housing available for this turbo is a 82 cause it has a smaller wheel then all the other gt30s so there exhaust housings dont fit, they used some diesel turbo housing and made it work, this is a 63 single entry, they are also making a 82 twin, that will be sent out soon, does anyone see any problems with the new housing where the gasket for the dump would sit?
    the old 82 housing
    new 63
  7. #67
    not really as ive used a few like that in the past, the main problem you will face is that they run a small PCD 4 bolt pattern and most of the others run a large PCD, it may require that if you change housings later the flange may also need to be changed.
    linden
  1. 4AGTE - Exhaust manifold warping
    By tan18d in forum Tech and Conversions
    Last Post: 05-05-2009, 05:36 PM
  2. 4agte clutch setups
    Last Post: 26-06-2008, 11:32 AM
  3. nitrous & 4agte
    By caibs in forum Tech and Conversions
    Last Post: 16-08-2007, 10:46 AM
  4. Getting 4agte conversion done... where in perth shall I go?
    By AE101LEV in forum Tech and Conversions
    Last Post: 25-05-2006, 07:59 PM
