Results 1 to 2 of 2
Thread: KE70 Vacuum Advance Pump
    Selangor
    Default KE70 Vacuum Advance Pump
    Does anyone have any spare parts source for a good
    vacuum advance pump used in the standard contact
    points distributor in the Corolla KE70'S 4K engine ?
    My original gave out a couple years ago, so I had to
    replace it with the "Century" brand OEM unit from Japan.
    This is the only brand available in Malaysia. They are
    poorly made and not durable. Firstly, the plastic fine timing
    adjuster at the end of the spring is not heat resistant - it
    becomes brittle and disintegrates after a few months, throwing
    the timing way off. Luckily, my brother-in-law managed to
    fabricate a copper one as a substitute, and it has been holding
    out well so far.
    The rubber diaphragm in the "Century" pump is also not
    durable. Mine lasted just about a year. Once the diaphragm
    gives out, the pump does not function anymore.
    If it gives way again, I'll probably change to a reluctor-type
    electronic distributor from the salvage yard. I'm currently using
    contact points with Silicon Chip magazine's high energy
    ignition unit (Dick Smith kit).
    Is not a good Backyard Mechanic GtiRboy's Avatar
    N.S.W
    Default Re: KE70 Vacuum Advance Pump
    probably better off trying in the wanted parts section in the classified
    Mmmmmmmm 2ZZGE
  1. MS85 Fuel Pump.
    By Brad-KE35 in forum Tech and Conversions
    Last Post: 31-03-2006, 09:12 AM
  2. Replies: 6
    Last Post: 06-02-2006, 07:20 PM
  3. 20V Brake Booster Vacuum Problems
    By ShiRi in forum Tech and Conversions
    Last Post: 15-12-2005, 07:06 PM
  4. Replies: 1
