Results 16 to 30 of 36
Thread: help please 1uz questions
    Default Re: help please 1uz questions
    You've lost me.
    wtf does the Aristo have to do with anything if you have a 1UZ loom and a 1UZ box ?
    the later 1uz box has different plugs to the earlier one (which is the motor/ box combo i bought motor being what ive used int he cressida)
    and the 1uz box which has the slip yoke im not using for that exact purpose as i dont want to mod my tailshaft...
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
    The flanged yoke Celsior and Soarer boxes have identical plugs to the slip yoke Crown box, with the exception of the rear speed sensor.
    will the crowns different speedo pulse work on a jzx81 digital dash? if so then ill just have to bite the bullet and have a new flange made for the gearbox with the flanged end. and you are right, the plugs are the same now i did some more looking...just a simple case of wiring up the speedo sensor yeah?
    Not the speedo sensor, the rear speed sensor, ie the ABS sensor/sensor so the ecu knows what speed the car is doing.
    Way too old to be a Grease Monkey stevevp's Avatar
    Dec 2006
    My setup is from a uzs141 Crown Majesta/Aristo, so I might be able to help with wiring.
    What was your gearbox from again? J/UZS161 may be a 5 speed - check the blue plate on the drivers side of the box and let us know what it says
    Steve
    1992 MX83 Cressida powered by 1UZ-FE - A little bit Toyota, a little bit An-i-mal
    1981 Porsche 928S "Herr Vader"
    Quote Originally Posted by Robbos_Toyotas
    thanks peewee - do u know where i could get the jzs161 aristo gearbox wiring from? would supra be the same plugs etc ud assume?
    I'm really quite sure you mean JZS147
    Not JZS161.
    And why on earth aren't you just using the 1UZ auto?
    Wilbo's JZA80
    Wilbo's JZZ12
    Not JZS161.
    i didnt want to change tailshaft, but ive decided fuck it im gonna use it and have something made for the slip yoke to make it work
    cheers guys
    Its a two-piece shaft right? so maybe chase up the front piece off a 1UZ car (assuming the middle is the same) and that way avoid having to make something up?
    Quote Originally Posted by Sciflyer
    nah i had a 1000hp tailshaft made which cost me $1000 when i was going to put the 2j in, hence i was reluctant to modify it....is v8 supercar spec im told...anyway i just have to mod the front piece to accept a yoke, which hardie spicer now have in stock and can put a massif uni on...
    hey all, another question. Does anyone know what the two 4 wire plugs with the blue and white thick wires do? one goes with the small loom near the afm and the other goes witht he starter cable loom....are these for the air suspension or?
    car in question was uzs131 early model
    Its been a few years since I've played with a UZS131 loom, but I don't recall either of those plugs existing on mine.
    Granted it was a cut loom, and thus butchered, but the wire colour/size doesn't ring a bell.
    peewee do u know what "ECT" means, theres a plug on the ecu with 7 wires and all control exhaust flap and go to this ËCT"- is that the traction control computer? looking at the wiring diagram its something else as the other wires are listed as going to a traction control ecu. with all the wiring i got i did get a computer looking thing with ECT written on it, but have nfi what it is/ does
    the two wires in question are L4 to ect,
    and F/C to ect
    ECT = Electronically Controlled Transmission ?
    Question mark is not needed. That is what it is
    Wilbo's JZA80
    Wilbo's JZZ12
  1. 1UZ into MA61 / MZ10 Guide.
    By CrUZida in forum Engine & Driveline Conversions
    Last Post: 01-09-2013, 07:27 PM
  2. 1uz oil filter locations
    Last Post: 28-03-2008, 06:46 PM
  3. 1UZ VVTI... Wiring questions.
    By MWP in forum Tech and Conversions
    Last Post: 07-06-2007, 04:00 PM
  4. Replies: 23
    Last Post: 29-04-2007, 01:18 PM
