Results 16 to 18 of 18
Thread: 7mge into MA61 idle seeking
    Default Re: 7mge into MA61 idle seeking
    If the ecu is wired correctly (ie, using a EFI main relay that the ecu triggers), then the ISCV will be reset every time you turn the car off (thats the click click click you hear).
    If the throttle plate is 100% closed, there is no vac leaks, and the TPS is in IDL mode, then the idle will not need adjusting. The ecu will adjust it to suit.
    If you haven't pulled the ISCV off and cleaned it, do so. Pull it apart and make sure the bearings run smoothly.
    Team Thrash Garage's Grease Monkey VikingDrift's Avatar
    victoria
    ahh has not been cleaned that just may be the go thanks mate
    victoria
    i'm actually using the factory body loom efi relay, not triggered by the ecu, how will that be any different?
  1. 5ME -> 7MGE conversion in MA61?
    By RObErT_RaTh in forum Tech and Conversions
    Last Post: 13-02-2011, 08:50 PM
  2. 5MGE into MA61 (changed from 7MGE)
    By RObErT_RaTh in forum Engine & Driveline Conversions
    Last Post: 04-11-2006, 09:25 AM
  3. 7MGTE W58 Odd Rattle at idle...
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 04-12-2005, 11:38 PM
