Results 1 to 15 of 18
Thread: 7mge into MA61 idle seeking
    Team Thrash Garage's Grease Monkey VikingDrift's Avatar
    victoria
    Default 7mge into MA61 idle seeking
    G'day guys, just put a 7mge + w58 into my girlfriends supra, everything is fine except it idles like at 1500, climbs to 2grand, then drops down to 1500 again, it also seems to run a little bit rough when driving, kind of lags before it makes power. We checked the iscv plug and are fairly sure it works, and other ideas? i also had a hunt for vacuum leaks.
    Mar 2008
    inner west syd now!
    Default Re: 7mge into MA61 idle seeking
    ISCV is usually causes 'hunting for idle' although my 5m-ge ma61 was doing it last week, mine is a pre-84 model 5m, so its all analogue sh#t, no iscv for me!!
    i'd say your on the right track with vac leaks, but as said, iscv it usually wat causes it! have you pulled codes yet??
    Have a quick search, this gets brought up every week.
    victoria
    i have had a bit of a search, can't find much useful, do you know what the problem is?
    victoria
    yeah i'v looked through that diagram, the pin numbers on the ecu don't match so we can't really firgure out the loom 100% do you think its the iscv?
    Ahh, its a Cressida ecu is it ?
    Have you verified that the ISCV is getting +12v ?
    Does it go click-click-click when you turn the car off?
    Does the IDL contact on the TPS work properly?
    Is the throttle butterfly 100% closed when your foot is off the pedal?
    victoria
    yep cressy ecu,
    yes it is now, we had to wire up the 12v to the iscv it wasn't actually getting it,
    no i don't think it clicks
    i'm not sure about the dil contact, how do i check that?
    and i'll look into the butterfly thing fairly sure it does i had a bit of a look at that when i put the cable on.
    thanks mate
    victoria
    oh also we couldn't get a code, can't find the engine warning light wire from the supra diagrams, do you know which one that is?
    check engine light is the W pin
    crack open the ECU the PCB has the pin letters etched into on of the sides
    victoria
    ok cheers that means the engine light isn't on then and i'v got a wiring diagram, i'll have more of a look today should be cool now.
    victoria
    ok got it workin, my mate had a whole bunch of original toyota diagrams, that helped us find one extra ignition to the ecu that we needed, fixed the idle and power worries instantly, but now it won't idle till it's been driving for like 5 mins, even if it's hot.. lol any ideas about that? cold start injector timer thingy?
    Cold start injector is purely for that, cold starts. Once it has started, or if its not cold, it doesn't do anything.
    Go back to the idle circuits, also make sure the ecu is seeing the correct coolant temperature.
    victoria
    oh ok cool thanks saved us a wild goose chase there lol i'll do that, should i reset the iscv? also is there a way to adjust the idle? it could be higher even when it doesn't die
  1. 5ME -> 7MGE conversion in MA61?
    By RObErT_RaTh in forum Tech and Conversions
    Last Post: 13-02-2011, 09:50 PM
  2. 5MGE into MA61 (changed from 7MGE)
    By RObErT_RaTh in forum Engine & Driveline Conversions
    Last Post: 04-11-2006, 10:25 AM
  3. 7MGTE W58 Odd Rattle at idle...
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 05-12-2005, 12:38 AM
