Results 1 to 3 of 3
Thread: w58 slave differentces
    Junior Member Backyard Mechanic Azzamk2's Avatar
    western aus
    Default w58 slave differentces
    we put a 7m and w58 into a ma61 and we cant get much clutch? we can select 2nd just but all other gears grind i only need a little bit more clutch i was thinking maybe ma61 and ma70 slaves might be different the ma70 have longer pushrod thingy for the slave? any help would be great and yes the clutch system has been bleed properlly
    Victoria, Mt Macedon
    Default Re: w58 slave differentces
    You can make your own clutch rod from any piece of rod you have handy. So you can try any length.
    I always find it a little illogical, so think carefully about it. When your clutch is new (I assume it's a new clutch), the pressure plate fingers sit closer in toward the flywheel, so the clutch fork sits further away from the slave cylinder. So be sure that there is still some stroke left to compress the slave when the clutch is released, otherwise you might get issues as the clutch wears.
    If it is properly bled, double check that master and slave aren't broken either.
    Hen
    Slaves and masters are the same sizes I'm quite sure.
    Check your adjustment at the pedal end is my suggestion
    Wilbo's JZA80
    Wilbo's JZZ12
  1. Clutch Slave Cylinders (W58)
    By e30-323ti in forum Tech and Conversions
    Last Post: 12-01-2006, 11:36 PM
