Hi Rodger
I've started a thread up in the tech if you wish to post there so other may see.
http://www.toymods.net/forums/showthread.php?t=46590
Yes the does flutter off a standing start only when you need the extra power to get going in a hurry Normal/Light driving no flutter.
OK so let me see your saying that maybe my nozzles a dribbling not spraying. Well when i rebuild the engine i also replaced all the carbies gaskets. and i test the nozzle to see if the meet the specs in the tractor manual. the spray duration was little shorter but the spray was more of a stream then a spray. Is there anyway of changing this? I not sure if you missed it but the accelerator pumps are currently disconnected ie spilt pin and washer removed and the mixture still dropped to 10.
Is it possible to Reduce to pump jet in these carbies? I thought the pump jet was in the casting.
I'm almost positive the pump are to blame if your foot is down a bit already not flat spot to WOT
Next the ignition mapping was setup on the dyno and is electronically controlled. 12 degrees static and 35 at 5000
straight line between the too. No vac advance although was looking into placing a MAP sensor into the controller for this. MAP sensor is connected and was also data log with the AFR next RPM .
Ok outer venturi size in 30
OK the AFR at idle i believe to be fine the lean reading is for 2 reasons: 1 the sniffer pip is unable to gain accurate reading below 2000 rpm, 2 the overlap in the cams. If the cruising mixtures are fine I'm happy to leave the Pilots as they are.
Cheers for all the info and knowledge everyone tells be to swap to Webber sure they are easier to get parts for and to fine people to tune them but I'm loving the sound of the Solex at WOT just hope i can sort this out.
Jason
Originally Posted by
Rodger
Hi Jason.
I love this. Fantastic work. Now I have some good reference material
First up I see no real dangers present in what you see in the mixtures. Just a pain in the arse. Even the extreme lean readings. Of course if it where to run like that for all time then it will be detrimental. You are watching and not letting it go on too long, which is good.
Check the fuel map on the couple of my motors on the xT dyno thread.
Even with your engine specs it should be drivable and cruise ok but one issue leads into the next as you go through the transitions.
As a starter, do you know what timing and advance curve you have? Mine is currently 10 static and I use the 12 degree slot in the dizzy mechanical advance. For 34 degrees total mechanical and no vacuum and on ULP.
Now.
If the engine hesitates and flutters around when moving off from the lights or an intersection then it is dangerous and we need to fix this. Most times it is caused by mal-functioning pump circuits, some or all not working correctly. If they are dribbling out it can cause the next issue you discribe, but this would be noticable off the line and this is where to look first.
The flat spot on sharp acceleration and from what you have discovered is present from a too rich shot of fuel over a too short time and could be the fact they are not a clean shot caused by above. If all is ok then it probably needs a longer leaner shot. So a smaller size of pump jet and back to the same stroke length.
Of course this response only happens in the first 20% of throttle movement so if a broard flat spot is present during a full throttle run from low revs, once over any initial hessitation, is now caused by air speed. Here the cams and venturi come into play. We could also explore the choice of bleed pipe as this has an effect on the transition point from pilot to mains. We can experiment with a couple of styles to see if we can match the cams and venturi.
Can you recall what size outer venturi you have?
If it is siting at 13 and the idle is 17.5 it may well be worth trying one more size up Pilot. A #62.5. It will mean you can come back a bit on the idle mixture screw but may then be a bit rich at cruise.
Regards
Rodger
