Page 7 of 34 FirstFirst ... 5678917 ... LastLast
Results 91 to 105 of 496
  1. #91
    Chiba
    Looks sweet. I love machined parts.
  2. #92
    Jun 2008
    Monday, 27 April 2009
    Engine is in!
    Interior is on its way out!
    May have to look into the solid mounts / prius air con gear, but for now just going to get everything running off the motor, keep it simple & get it running fast!
  3. #93
    not sure if mentioned elsewhere but what are you using for a heat source for the demister?
  4. #94
    Jun 2008
    Got a 240v ceramic heater element to install where the old heat exchanger is.
    Will have it hooked up to the fan control & thermal protection to avoid meltdowns
  5. #95
    had you thought about using an automatic gearbox? or would that lead to less distance/endurance (motor always running to keep hydraulic pressure up to gearbox)?
  6. #96
    Jun 2008
    -thechuckster
    Will be sticking with the manual, less drive losses & more fun for rippn skids
    -A
  7. #97
    Looking the goods, if you're running the AC comp off the motor are you going to have an RPM switch for the clutch or just run the motor on idle?
  8. #98
    This is nukin futs!
    Cant wait to see it whizzing along.
  9. #99
    Jun 2008
    -Talasas
    Currently planning to idle the motor so the power steering / ac work.
    Will put in a switch to override if need be (for easy hill starts, long waits @ lights etc...)
    Will eventually like to have another accessory motor, or individual powered units.
    Picking up metal for the battery box this arvo, should have it bent up and ready to test fit this weekend.
    -A
  10. #100
    Fear the Rapeodile Carport Converter blakeg's Avatar
    May 2006
    dont know if its already been mentioned ? but is the motor able to act in a regenerative way when going down hill or slowing down ?
    and cant wait to see more results .
  11. #101
    Jun 2008
    -blakeq
    Yep, but need additional electronics and mods to speed controller.
    Not planning to implement just yet, maybe further down the track.
    -A
  12. #102
    C'mon, Touch My Grease Monkey SLO-030's Avatar
    Feb 2009
    im liking this ALOT. Great work
    Member Of The Leaf Sprung Axle Trampers Club
  13. #103
    vic
    Just a thought , if the electric motor will see high rpm like the petrol engine id put the ring gear back on . A cast flywheel will explode without the ring gear on .
    Id say up to 4000 rpm would be safe without the ring gear tho .
    Dave
  14. #104
    Quote Originally Posted by cambelt
    Dave
    you mean the ringgear prevents the cast flywheel from cracking in the first place? or by containing the pieces after it cracks?
    surely the ring gear will stretch enough to not prevent crack formation?
  15. #105
    Jun 2008
    Interesting,
    I have seen many ppl remove the ring gear for other leccy cars.
    I doubt there will be many full revs + clutch dumps going on, so I cant see it getting hurt too much.
    -A
    Last Post: 08-01-2006, 12:27 AM
